  4. Latest Dyno run
Latest Dyno run
32 Posts 17 Posters 1.8k Views
  • XJHEADX Offline
    XJHEADX Offline
    Thanx all, I am still searching for some more power though, not too sure where I am going to find it. Numbers I think are down from where it should be. Guys running these set-ups just don't like giving out too much info.
    • 94NDTA9 Offline
      94NDTA9 Offline
      I think you have the highest rwhp of anyone on this site.
        Did you swap out the valve springs yet?
        • XJHEADX Offline
          XJHEADX Offline
          Yep did that before the tangs were put in. Back pressure with new housings and 4" dual is only at 1.1 - 1 backpresure ratio.
            IMO you got a bottlekneck still somewhere from looking @ the graphs and how each boost level follows the same curve.
            You gonna get another cam coming? Swap out that intake if Andy has that other one, got nothing to lose.
              you think?
              • EvanE Offline
                EvanE Offline
                Evan
                Congrats on the numbers. nice car too.
                > bubba;204638 wrote:
                <u>Past Rides:</u>
                -2003 Dr-Z 125-Sold
                <u>Current Rides:</u>
                • XJHEADX Offline
                  XJHEADX Offline
                  Going back to the dyno again this week. I made another change. This is starting to get old....Need to wake these turbos up, they are still pretty lazy...
                  • XJHEADX Offline
                    XJHEADX Offline
                    Got back on tues night with some new numbers. I did a cam change over the W/end. Thanx for the help MisterCMK:p: . Anyways final number was 1150 RWHP. Need to clean the pig up and save it for SEMA at the end of the month. Hopefully be in the top 5 with these numbers..
                    • M Offline
                      M Offline
                      musthavemuzk
                      good luck!!
                      Monty
                      14.59 at 94.85 still stock
                      www.pbase.com/musthavemuzk
                        probe this
                        4 valve heads? more boost? bigger turbo? NITROUS!!!
                        Not sure what all you have done, but some things to look at.
                        My probe is fast. How fast? Line up next to me at the track and find out.
                        I can pull my probe faster than most ricers can race. haha
                        99 black lightning 496whp, 620ft/lbs heavy pig
                        • XJHEADX Offline
                          XJHEADX Offline
                          probe this;188769 wrote:
                          4 valve heads? .
                          Not available
                          more boost?.
                          Running plenty, doesn't like more
                          bigger turbo's?.
                          Big enough
                          NITROUS!!!.
                          Thought about it
                          Pretty much everything.
                          • capitljC Offline
                            capitljC Offline
                            capitlj
                            VTEC? lol
                            There is always more power out there but I've never driven anything with more than 550 so ummm yeah
                            > Mitch Hedberg wrote:
                            2004 Impala LS 3.8
                              I've never been in a car with remotely close to that power must be sweet!
                              • XJHEADX Offline
                                XJHEADX Offline
                                Running out of fuel now
                                • M Offline
                                  M Offline
                                  musthavemuzk
                                  well that sux
                                  Monty
                                    Fuel problem solved, that thing needs a LOT of fuel.
                                      what was up?
                                      • M Offline
                                        M Offline
                                        musthavemuzk
                                        alot as in more than the 2jz you, Matt or that GS300 run? or similar?
                                        as i remember Matt talking about running 3 fuel pumps to supply enough fuel for his. at least i think he said 3. mayb it was the GS300 that ran 3.
                                        Monty
                                          Bill runs E85, so he needs about 30% more fuel than if he were using gasoline. He was out of fuel pump. He put on my Weldon and that still wasn't enough. Now he has his pump and my Weldon both running in parallel.
