  3. Wanted Ads
  4. wtb dsm 6 bolt
wtb dsm 6 bolt
33 Posts 8 Posters 4.1k Views
  • black2gB Offline
    black2gB Offline
    black2g
    anyone have a 6 bolt dsm block laying around??
    1995 Eagle Talon
    2000 Doge Neon
    1974 Porsche 914
    • H Offline
      H Offline
      hondacivicchris
      got one with a bad mane barring
      • W Offline
        W Offline
        Wizard
        I got 2, but only one with matching main caps.
        Come and get em.....
        Wiz
        1992 GVR4 598/1000 Nile Black
        1992 Tsi AWD
        1982 Datsun KC 4x4
        1990 Laser 2.0 AT NT
        1994 ES 2.0L NT 5-spd
        • black2gB Offline
          black2gB Offline
          black2g
          just the main bearing is bad or is the crank/journals damaged badly? do you have piston and rods to?
          1995 Eagle Talon
          2000 Doge Neon
          1974 Porsche 914
          • black2gB Offline
            black2gB Offline
            black2g
            Wiz
            whats the story on the one with matching rod caps? piston/rods? apx millage? any major signs of wear?
            1995 Eagle Talon
            2000 Doge Neon
            1974 Porsche 914
            • black2gB Offline
              black2gB Offline
              black2g
              I want to get a somewhat decent block. Possibly built but I'm not to picky. Just want something that is not trashed.
              1995 Eagle Talon
              2000 Doge Neon
              1974 Porsche 914
              • black2gB Offline
                black2gB Offline
                black2g
                bump
                1995 Eagle Talon
                2000 Doge Neon
                1974 Porsche 914
                • GnArKiLlG Offline
                  GnArKiLlG Offline
                  GnArKiLl
                  talk to assasan last time i was up there he had 2 i think
                  1976 Chevy K5- lifted beater
                  • black2gB Offline
                    black2gB Offline
                    black2g
                    k i'll try pm him. thanks.
                    1995 Eagle Talon
                    2000 Doge Neon
                    1974 Porsche 914
                    • H Offline
                      H Offline
                      hondacivicchris
                      the motor is all there never took it apart still ran when took it out had lower end noise
                      • black2gB Offline
                        black2gB Offline
                        black2g
                        i started researching the compression differences on the turbo vs non-turbo and i says the non-turbo 1g has 9.2:1 and the turbo has 7.8:1. the turbo 2g has 8.5:1. does anyone know if there is anything wrong with the 1g non-turbo block. i know if you run to much compression with a turbo it with knock but besides that do the blocks have many differences? can i swap turbo parts on a non-turbo 4g63? head bolts/manifold bolts and so on? If the blocks are just as strong on the 1g non-turbo 4g63 i would rather go with that block. any arguments? also i noticed the bore and stock are slightly different on the 1g engines( esi and tsi) but both have the same displacement.
                        1995 Eagle Talon
                        2000 Doge Neon
                        1974 Porsche 914
                          The blocks themselves are identical other then oil squirters.
                          • black2gB Offline
                            black2gB Offline
                            black2g
                            ^^^^are you talking about the 1g and 2g?? i was wondering on the 1g esi and the 1g tsi. because the compression ratios and bore/stoke are differant but i should be the same block right? I just wanted to make sure because of the minor bore differences. thanks
                            1995 Eagle Talon
                            2000 Doge Neon
                            1974 Porsche 914
                              I was referring to the 1G turbo and NA 4G63 block. The 1G base model was a SOHC and used a different block, i believe that was the DL model.
                              • black2gB Offline
                                black2gB Offline
                                black2g
                                ^^yeah but that was a 1.8L. do you know if the turbo blocks were build any stronger?
                                1995 Eagle Talon
                                2000 Doge Neon
                                1974 Porsche 914
                                  Did you not pay attention when i said they were identical other then the oil squiterters.
                                  • black2gB Offline
                                    black2gB Offline
                                    black2g
                                    k thanks
                                    1995 Eagle Talon
                                    2000 Doge Neon
                                    1974 Porsche 914
                                    • black2gB Offline
                                      black2gB Offline
                                      black2g
                                      bump. still looking. I would like to get a motor from a non-turbo 1g. It would be nice to get crank/rods/pistons/block all together. thanks
                                      1995 Eagle Talon
                                      2000 Doge Neon
                                      1974 Porsche 914
                                      • beachbum_jonB Offline
                                        beachbum_jon
                                        um...didnt the turbos and non-turbos have different pistons?
                                        -John Adams, 1735-1826-
                                        • GnArKiLlG Offline
                                          GnArKiLlG Offline
                                          GnArKiLl
                                          yes Jon non turbo's had higher compression pistons
