  3. Wanted Ads
  4. wtb dsm 6 bolt
wtb dsm 6 bolt
33 Posts 8 Posters 4.9k Views
  • black2gB
    black2gB
    black2g
    anyone have a 6 bolt dsm block laying around??
    1995 Eagle Talon
    2000 Doge Neon
    1974 Porsche 914
    • H
      H
      hondacivicchris
      got one with a bad mane barring
      • W
        W
        Wizard
        I got 2, but only one with matching main caps.
        Come and get em.....
        Wiz
        1992 GVR4 598/1000 Nile Black
        1992 Tsi AWD
        1982 Datsun KC 4x4
        1990 Laser 2.0 AT NT
        1994 ES 2.0L NT 5-spd
        • black2gB
          black2gB
          black2g
          just the main bearing is bad or is the crank/journals damaged badly? do you have piston and rods to?
          1995 Eagle Talon
          2000 Doge Neon
          1974 Porsche 914
          • black2gB
            black2gB
            black2g
            Wiz
            whats the story on the one with matching rod caps? piston/rods? apx millage? any major signs of wear?
            1995 Eagle Talon
            2000 Doge Neon
            1974 Porsche 914
            • black2gB
              black2gB
              black2g
              I want to get a somewhat decent block. Possibly built but I'm not to picky. Just want something that is not trashed.
              1995 Eagle Talon
              2000 Doge Neon
              1974 Porsche 914
              • black2gB
                black2gB
                black2g
                bump
                1995 Eagle Talon
                2000 Doge Neon
                1974 Porsche 914
                • GnArKiLlG
                  GnArKiLlG
                  GnArKiLl
                  talk to assasan last time i was up there he had 2 i think
                  1976 Chevy K5- lifted beater
                  • black2gB
                    black2gB
                    black2g
                    k i'll try pm him. thanks.
                    1995 Eagle Talon
                    2000 Doge Neon
                    1974 Porsche 914
                    • H
                      H
                      hondacivicchris
                      the motor is all there never took it apart still ran when took it out had lower end noise
                      • black2gB
                        black2gB
                        black2g
                        i started researching the compression differences on the turbo vs non-turbo and i says the non-turbo 1g has 9.2:1 and the turbo has 7.8:1. the turbo 2g has 8.5:1. does anyone know if there is anything wrong with the 1g non-turbo block. i know if you run to much compression with a turbo it with knock but besides that do the blocks have many differences? can i swap turbo parts on a non-turbo 4g63? head bolts/manifold bolts and so on? If the blocks are just as strong on the 1g non-turbo 4g63 i would rather go with that block. any arguments? also i noticed the bore and stock are slightly different on the 1g engines( esi and tsi) but both have the same displacement.
                        1995 Eagle Talon
                        2000 Doge Neon
                        1974 Porsche 914
                        • P
                          P
                          The blocks themselves are identical other then oil squirters.
                          • black2gB
                            black2gB
                            black2g
                            ^^^^are you talking about the 1g and 2g?? i was wondering on the 1g esi and the 1g tsi. because the compression ratios and bore/stoke are differant but i should be the same block right? I just wanted to make sure because of the minor bore differences. thanks
                            1995 Eagle Talon
                            2000 Doge Neon
                            1974 Porsche 914
                            • P
                              P
                              I was referring to the 1G turbo and NA 4G63 block. The 1G base model was a SOHC and used a different block, i believe that was the DL model.
                              • black2gB
                                black2gB
                                black2g
                                ^^yeah but that was a 1.8L. do you know if the turbo blocks were build any stronger?
                                1995 Eagle Talon
                                2000 Doge Neon
                                1974 Porsche 914
                                • P
                                  P
                                  Did you not pay attention when i said they were identical other then the oil squiterters.
                                  • black2gB
                                    black2gB
                                    black2g
                                    k thanks
                                    1995 Eagle Talon
                                    2000 Doge Neon
                                    1974 Porsche 914
                                    • black2gB
                                      black2gB
                                      black2g
                                      bump. still looking. I would like to get a motor from a non-turbo 1g. It would be nice to get crank/rods/pistons/block all together. thanks
                                      1995 Eagle Talon
                                      2000 Doge Neon
                                      1974 Porsche 914
                                      • beachbum_jonB
                                        beachbum_jonB
                                        beachbum_jon
                                        um...didnt the turbos and non-turbos have different pistons?
                                        -John Adams, 1735-1826-
                                        • GnArKiLlG
                                          GnArKiLlG
                                          GnArKiLl
                                          yes Jon non turbo's had higher compression pistons
