  4. 91 explorer parts
91 explorer parts
12 Posts 5 Posters 1.1k Views
  • lord_deastofactL
    lord_deastofactL
    lord_deastofact
    anyone know if there are any crazy differences between 91-92 explorers? I am looking at getting one for parts, mostly brakes and tranny. Just want to know if ford changed stuff so it won't fit. and also if I do get it, i will have lots of extra parts if anyones interested in buying the rest of it from me.
    Minute ricer!
    • MisterCMKM
      MisterCMKM
      It'll work. Let me know if you need help with anything, the Explorers are easy to work on. If you are picking up a parts truck, let me know. I need a few things. Look for one in a dark metallic red if you can. 😄
      thrash;315544 wrote:
      Ford is back :)
      • lord_deastofactL
        lord_deastofactL
        lord_deastofact
        well I don't know if your interested cmk, but I had thought of if someone that knew more about the tranny and 4x4 parts wanted to swap them for me, they could have the rest of the one i'm buying, in good condition cept the engine is alittle f'd guy ran it out of water and overheated it.
        Minute ricer!
        • BookemB
          BookemB
          Bookem
          Hey Chris, do the exploder's have the dana 44 front split beam or whatever they call it? If so I would like to check out some parts as well.
          Legacy GT
          Gmc Suburban
          Hallorann: Fargostreet?
          Hallorann: No, I ain't.
          • MisterCMKM
            MisterCMKM
            If the engine was overheated the head could have warped as they do that easily.
            I would definitely be interested. PM me and we'll talk.
            Ford is back :)
            • MisterCMKM
              MisterCMKM
              They have a D35 TTB front end. You would want to look for an F-150 to have the D44 TTB
              Ford is back :)
              • dubbsyD
                dubbsyD
                what 4 wheel drive parts do you need swapped?
                • lord_deastofactL
                  lord_deastofactL
                  lord_deastofact
                  I am honestly not sure, but when it's cold and i turn on 4wheel drive I get a random clunk like it is slipping, not sure if it's the hubs or something else, I don't know very much about the innerworkings of 4wheel. but only the parts that would fix that, I have no idea how hard it would be, any thoughts?
                  Minute ricer!
                  • DrifterExtremeD
                    DrifterExtremeD
                    i thought all 4wd trucks clunk some going into 4wd?
                    • lord_deastofactL
                      lord_deastofactL
                      lord_deastofact
                      not going in, when I'm driving once it's on. so I never use it. not in any pattern that would tell me if it was worn in one spot, but rather randomly, it will not do it for 8 blocks then do it a bunch in half a block. I am not sure what it is, but figured it was bad and just didn't use it.
                      Minute ricer!
                      • dubbsyD
                        dubbsyD
                        very possibly the hubs slipping. Those had an issue with not fully engaging (my 94 did and I believe Chris's did so he now has Warn manual hubs). The hubs are supposedly rebuildable but I'd have to find the link here with the bearing info (cheaper to buy the bearing from somewere like bearings and drives vs getting the kit from Ford).
                        • MisterCMKM
                          MisterCMKM
                          Probably the hubs. I have an extra set of auto hubs or you can convert to manuals like I did. Well worth it to convert.
                          Ford is back :)
