  3. Wanted Ads
  4. somone to build an intake manifold
17 Posts 9 Posters 648 Views
    all i have to say is good luck.... i know someone who could do it, but for anything under $500 it wouldn't be worth it.
    • GnArKiLlG Offline
      GnArKiLlG Offline
      GnArKiLl
      all i realy need are the parts cut and milled i cna have them welded here
      1976 Chevy K5- lifted beater
        just buy one cheap skate!
          I've never understood those style of intake, wouldn't a more rounded one flow better? That and their ugly as hell..
            ... just buy one ...
            • 9 Offline
              9 Offline
              91teggy
              I think i might start putting something like that together at work for the teg
                do either of you plan on making above 400 hp??? if not don't waste your time cuz it looks cool...
                  W/o cams and a supporting turbo an intake of that nature will do you absolutely no good. Having the parts machined and built is the expensive part, not the welding.
                  On a side note if your not willing to pay for it you probably dont need it. Buy one off Ebay then kick yourself when it doesn't make power.
                  • GnArKiLlG Offline
                    GnArKiLlG Offline
                    GnArKiLl
                    as far a s the set up it going on a car with a pte 57 trim, hks 272 cams, manely VS and retainers.. andi know the welding is the cheap part i just dont have the stuff to round out the holes..
                      http://www.rossmachineracing.com/
                      this should get you some stuff you need, but the flange will be spendy
                        just find a used Magnus...
                        • GnArKiLlG Offline
                          GnArKiLlG Offline
                          GnArKiLl
                          i have a flange already..
                          wannabe- i would if i could find one! also its kinda nice when ppl ask "what brand is that?" and you can say i made that..
                          • thurmanmermanT Offline
                            thurmanmerman
                            If someone other than you does the machining and someone else does the welding that doesn't mean you made it. It just means you paid for it to be made.
                            > Parker;299126 wrote:
                            • 9 Offline
                              9 Offline
                              91teggy
                              If i do get around to it i could do it all at work getting paid while im making it and buying only some of the aluminum so it will cost very little and my car is always a work in progress who knows where it will take me.
                              • D S ohMD Offline
                                D S ohMD Offline
                                D S ohM
                                check dsmtrader lately?
                                I wanna go fast!
                                • GnArKiLlG Offline
                                  GnArKiLlG Offline
                                  GnArKiLl
                                  yea cant find anything
