auto x!!
it should net me roughly 400-450whp...and yes, i know that logs are not as efficient as equal length tube, but you can control wheelspin with throttle control, you dont have to bury your foot every time you press the gas pedal...there are plenty of people that use this turbo on this motor, also a very popular turbo for the rb25det, which is a whopping .1 liter larger than the KA. and like faber said, it will be a .82 a/r. and this turbo is more efficient than a 57 trim, so there is more headroom, to a certain extent. I am not claiming to be a turbo genius, but I have done my homework/alot of research.
revolutionz_s13;196191 wrote:
LOL...I am pretty sure I know what I am doing....dont need to ask Faber for advice...I am the one that originally tuned his car when he first got it running with the safc
revolutionz_s13;196230 wrote:
I am not claiming to be a turbo genius, but I have done my homework/alot of research.Could have fooled me, i thought that anyone who knew how to operate an AFC was a turbo master........;)
lol...i see now that came out kinda wrong (sometimes i forget you cant have a "tone of voice" on the internet)...but you know, maybe i will run a safc in mine, so i can continue to improve on my "turbo master" status :icon_cheers:
but you can control wheelspin with throttle control, you dont have to bury your foot every time you press the gas pedal....That i would have to see....
may be possible to an extent with a small turbo like that
Matt is right, even on my car the 57trim would fall off up top
well, fabers turbo(AMS GT32) is roughly equivalent to a garrett 50 trim, .60 a/r. Which is smaller in size and probably less efficient (AMS wont give out the exact specs) than a GT3076R, .82 a/r. Faber has no problems up top, I dont think I will have to worry about that. There is a guy on ka-t.org that is making 417whp with a similar setup to mine @ 19psi with a gt3076r .82 a/r.
my gt32 doesnt fall off up top! the turbo has a gt3251e CHRA, with custom precision housings. IMO the turbo is like a 57trim out put wise, while spooling like a 50trim(all refering to t3/t4, .63AR)
and WTF do you mean buy 57trim. you need to be WAY more specific about those things. There are thousands of differant 57trim turbos on the planet.
assuming i get my POS together and down to the cities to get tuned....
KA-T_240;196278 wrote:
my gt32 doesnt fall off up top! the turbo has a gt3251e CHRA, with custom precision housings. IMO the turbo is like a 57trim out put wise, while spooling like a 50trim(all refering to t3/t4, .63AR)and WTF do you mean buy 57trim. you need to be WAY more specific about those things. There are thousands of differant 57trim turbos on the planet.
he means a t3/t4 57 trim... the "tufte turbo". Even I knew that.
wannabe;196287 wrote:
he means a t3/t4 57 trim... the "tufte turbo". Even I knew that.OMG you think I am THAT dumb? Of course i knew what he meant.
I am just saying what i said. my dad gets some people every once and while that come in asking for a 50 or 57trim. my dad knows what they are. but is always like which one, there is thousands and gets the dumbest look on the kids faces.
wannabe;196290 wrote:
lol, you confuse me faber, if you didn't mean it, why did you say it, and go into detail?ahahahahah, have you ever met faber? and did you really have to ask?:D
revolutionz_s13;196277 wrote:
well, fabers turbo(AMS GT32) is roughly equivalent to a garrett 50 trim, .60 a/r. Which is smaller in size and probably less efficient (AMS wont give out the exact specs) than a GT3076R, .82 a/r. Faber has no problems up top, I dont think I will have to worry about that. There is a guy on ka-t.org that is making 417whp with a similar setup to mine @ 19psi with a gt3076r .82 a/r.now see i'm running the same turbo same specs, i got the atp 3" v-band.
now with my motor i should see full boost buy say 4800ish give or take based on my monster manifold. now i rev to 9k so i will have a power band.
but unlike you i will not make near the torque you will, so all i'm saying is that you need to look at the fact that it will just make it harder fo ryou to drive the car to it's potential. but i spose we will see next year.
gt3076r, 18 lbs , high 200's for torque.
now this is with a small .48 turbine
http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=si&img=397509
on the KA, you will see ~400whp @ roughly 19-20psi, hitting full boost by roughly 5k-6k rpms(dont quote me on that....) depending on setup. That should net you depending on tuning, about 350ft-lbs of torque.
this would be the gt3076r with the .82 a/r turbinehere is a dyno from some guy down in georgia that has a similar setup to mine....
