  3. Track Talk
  4. auto x!!
auto x!!
170 Posts 30 Posters 25.1k Views
  • K
    K
    bubba you will be in SM due to motor swap.
    that makes 5 of us in SM for next year.
    • R
      R
      revolutionz_s13
      assuming i get my POS together and down to the cities to get tuned....
      MisterCMK;207559 wrote:
      Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
      • JoelJ
        JoelJ
        KA-T_240;196278 wrote:
        my gt32 doesnt fall off up top! the turbo has a gt3251e CHRA, with custom precision housings. IMO the turbo is like a 57trim out put wise, while spooling like a 50trim(all refering to t3/t4, .63AR)
        and WTF do you mean buy 57trim. you need to be WAY more specific about those things. There are thousands of differant 57trim turbos on the planet.
        he means a t3/t4 57 trim... the "tufte turbo". Even I knew that.
        • K
          K
          OMG you think I am THAT dumb? Of course i knew what he meant.
          I am just saying what i said. my dad gets some people every once and while that come in asking for a 50 or 57trim. my dad knows what they are. but is always like which one, there is thousands and gets the dumbest look on the kids faces.
          • JoelJ
            JoelJ
            lol, you confuse me faber, if you didn't mean it, why did you say it, and go into detail?
            • R
              R
              revolutionz_s13
              ahahahahah, have you ever met faber? and did you really have to ask?:D
              • K
                K
                What do you mean go into detail?
                I said it because i was trying to make a point.
                • bubbaB
                  bubbaB
                  So basically im fucked, lol...
                  • zbrownZ
                    zbrownZ
                    like faber said, trim is nothing more than (ind^2/exd^2)*100
                    57trim is just a common name given to a popular T04E compressor
                    My gt42 has a 53 trim compressor and 84 trim turbine....
                    if you have the trim # and either ind or exd it is easy to find the other
                    • DrifterExtremeD
                      DrifterExtremeD
                      revolutionz_s13;196277 wrote:
                      well, fabers turbo(AMS GT32) is roughly equivalent to a garrett 50 trim, .60 a/r. Which is smaller in size and probably less efficient (AMS wont give out the exact specs) than a GT3076R, .82 a/r. Faber has no problems up top, I dont think I will have to worry about that. There is a guy on ka-t.org that is making 417whp with a similar setup to mine @ 19psi with a gt3076r .82 a/r.
                      now see i'm running the same turbo same specs, i got the atp 3" v-band.
                      now with my motor i should see full boost buy say 4800ish give or take based on my monster manifold. now i rev to 9k so i will have a power band.
                      but unlike you i will not make near the torque you will, so all i'm saying is that you need to look at the fact that it will just make it harder fo ryou to drive the car to it's potential. but i spose we will see next year.
                      • zbrownZ
                        zbrownZ
                        kinda curious
                        so lets say 400whp....
                        how much boost would it take Matt to make that? and how much torque
                        vs
                        how much boost with the KA, and how much torque
                        with identical turbos; the ones you stated above
                        • DrifterExtremeD
                          DrifterExtremeD
                          gt3076r, 18 lbs , high 200's for torque.
                          now this is with a small .48 turbine
                          http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=si&img=397509
                          • R
                            R
                            revolutionz_s13
                            on the KA, you will see ~400whp @ roughly 19-20psi, hitting full boost by roughly 5k-6k rpms(dont quote me on that....) depending on setup. That should net you depending on tuning, about 350ft-lbs of torque.
                            this would be the gt3076r with the .82 a/r turbine
                            here is a dyno from some guy down in georgia that has a similar setup to mine....
                            • K
                              K
                              Ivan has 40psi on his gt42 sooner then 6k.
                              you should have around 20psi at like 4k.
                              • R
                                R
                                revolutionz_s13
                                eh maybe...like i said not too sure about that...i thought it would be about 4200-4400 from when i did all the calculations from the compressor map, but i wasnt sure if i figured right.
                                • K
                                  K
                                  you do remember how fast my turbo spools. and yours should spool around the same as mine does. The DBB should somewhat make up for you having a .82ar
                                  • DrifterExtremeD
                                    DrifterExtremeD
                                    ball bearing doesn't mean faster spool...... you should know that faber...haha
                                    • R
                                      R
                                      revolutionz_s13
                                      well in a round about way it does....it takes less force to spin a DBB cartridge than it does to spin a ceramic journal bearing cartridge...which means the turbo wheel will reach higher speeds faster...which means the compressor will flow more air faster = boost faster.
                                      • K
                                        K
                                        Yes, i know this. DBB makes the turbo more efficient, also get more devoted lubrication and coolin. and then what nate said.
                                        I would be hard, but if you have 2 identical turbos one with journal bearing and the other with the DBB, 95% of the time the DBB will spool faster then JB turbo,
                                        WITH ALL THINGS BEING EQUAL
                                        • DrifterExtremeD
                                          DrifterExtremeD
                                          borg warner? ....
                                          haha ok now i'm just being diffecult...
