  3. Track Talk
  4. auto x!!
auto x!!
170 Posts 30 Posters 25.1k Views
  • zbrownZ
    zbrownZ
    like faber said, trim is nothing more than (ind^2/exd^2)*100
    57trim is just a common name given to a popular T04E compressor
    My gt42 has a 53 trim compressor and 84 trim turbine....
    if you have the trim # and either ind or exd it is easy to find the other
    • DrifterExtremeD
      DrifterExtremeD
      revolutionz_s13;196277 wrote:
      well, fabers turbo(AMS GT32) is roughly equivalent to a garrett 50 trim, .60 a/r. Which is smaller in size and probably less efficient (AMS wont give out the exact specs) than a GT3076R, .82 a/r. Faber has no problems up top, I dont think I will have to worry about that. There is a guy on ka-t.org that is making 417whp with a similar setup to mine @ 19psi with a gt3076r .82 a/r.
      now see i'm running the same turbo same specs, i got the atp 3" v-band.
      now with my motor i should see full boost buy say 4800ish give or take based on my monster manifold. now i rev to 9k so i will have a power band.
      but unlike you i will not make near the torque you will, so all i'm saying is that you need to look at the fact that it will just make it harder fo ryou to drive the car to it's potential. but i spose we will see next year.
      • zbrownZ
        zbrownZ
        kinda curious
        so lets say 400whp....
        how much boost would it take Matt to make that? and how much torque
        vs
        how much boost with the KA, and how much torque
        with identical turbos; the ones you stated above
        • DrifterExtremeD
          DrifterExtremeD
          gt3076r, 18 lbs , high 200's for torque.
          now this is with a small .48 turbine
          http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=si&img=397509
          • R
            R
            revolutionz_s13
            on the KA, you will see ~400whp @ roughly 19-20psi, hitting full boost by roughly 5k-6k rpms(dont quote me on that....) depending on setup. That should net you depending on tuning, about 350ft-lbs of torque.
            this would be the gt3076r with the .82 a/r turbine
            here is a dyno from some guy down in georgia that has a similar setup to mine....
            MisterCMK;207559 wrote:
            Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
            • K
              K
              Ivan has 40psi on his gt42 sooner then 6k.
              you should have around 20psi at like 4k.
              • R
                R
                revolutionz_s13
                eh maybe...like i said not too sure about that...i thought it would be about 4200-4400 from when i did all the calculations from the compressor map, but i wasnt sure if i figured right.
                • K
                  K
                  you do remember how fast my turbo spools. and yours should spool around the same as mine does. The DBB should somewhat make up for you having a .82ar
                  • DrifterExtremeD
                    DrifterExtremeD
                    ball bearing doesn't mean faster spool...... you should know that faber...haha
                    • R
                      R
                      revolutionz_s13
                      well in a round about way it does....it takes less force to spin a DBB cartridge than it does to spin a ceramic journal bearing cartridge...which means the turbo wheel will reach higher speeds faster...which means the compressor will flow more air faster = boost faster.
                      • K
                        K
                        Yes, i know this. DBB makes the turbo more efficient, also get more devoted lubrication and coolin. and then what nate said.
                        I would be hard, but if you have 2 identical turbos one with journal bearing and the other with the DBB, 95% of the time the DBB will spool faster then JB turbo,
                        WITH ALL THINGS BEING EQUAL
                        • DrifterExtremeD
                          DrifterExtremeD
                          borg warner? ....
                          haha ok now i'm just being diffecult...
                          • zbrownZ
                            zbrownZ
                            thats interesting, thanks
                            for comparison here is what your typical 13b rew will do
                            here is a graph of a typical single setup.... gt 3582r---1.06a/r
                            13-15 psi, 320-340lb-ft, 400rwhp, full boost 4k
                            you need alot bigger turbo for the same power.......
                            • N
                              N
                              nvrdone
                              Ok, back to the class/setup thing.
                              1988 RX-7 GXL - Full suspension, coilovers, bushings, sways, everything.. Rebuilt 6-port n/a, itb's, prolly microtech lt8, cage..
                              guessing sm as its still a dd setup I hope :drunken_smilie:
                              2000 SC1 - S1 SPL car, 136.9db atm
                              1988 RX-7 GXL - waiting for my lazy ass to finish high comp turbo swap
                              • GarageAlchemistG
                                GarageAlchemistG
                                GarageAlchemist
                                id like to see that...
                                97 GTi, 03 KJ
                                • N
                                  N
                                  nvrdone
                                  Hopefully by next summer you will. Almost have enough saved for the rebuild.
                                  • King RicerK
                                    King RicerK
                                    damn sounds like the nice set-up! what was your name again?
                                    Trafik Jamz;299122 wrote:
                                    • JN210J
                                      JN210J
                                      JN210
                                      I will be running my stock setup(as if I have another anyway lol).....I just want to get a feel for the sport first, Im going to have some fun and learn a little bit.
                                      *1989 Nissan 300ZX Z31 *
                                      DelSlow;262050 wrote:
                                      I like the new JN210
                                      • zbrownZ
                                        zbrownZ
                                        for a whole 180 rwhp if you are lucky on a tuned S4 stock port 6 port......
                                        • bubbaB
                                          bubbaB
                                          Not everyone wants an enourmous turbo that needs anti-lag to spool and a million hp...some want something that'll work good for auto-x
