auto x!!
revolutionz_s13;196336 wrote:
on the KA, you will see ~400whp @ roughly 19-20psi, hitting full boost by roughly 5k-6k rpms(dont quote me on that....) depending on setup. That should net you depending on tuning, about 350ft-lbs of torque.
this would be the gt3076r with the .82 a/r turbinehere is a dyno from some guy down in georgia that has a similar setup to mine....
Ivan has 40psi on his gt42 sooner then 6k.
you should have around 20psi at like 4k.
eh maybe...like i said not too sure about that...i thought it would be about 4200-4400 from when i did all the calculations from the compressor map, but i wasnt sure if i figured right.
ball bearing doesn't mean faster spool...... you should know that faber...haha
well in a round about way it does....it takes less force to spin a DBB cartridge than it does to spin a ceramic journal bearing cartridge...which means the turbo wheel will reach higher speeds faster...which means the compressor will flow more air faster = boost faster.
Yes, i know this. DBB makes the turbo more efficient, also get more devoted lubrication and coolin. and then what nate said.
I would be hard, but if you have 2 identical turbos one with journal bearing and the other with the DBB, 95% of the time the DBB will spool faster then JB turbo,
WITH ALL THINGS BEING EQUAL
borg warner? ....
haha ok now i'm just being diffecult...
id like to see that...
nvrdone;196643 wrote:
Ok, back to the class/setup thing.1988 RX-7 GXL - Full suspension, coilovers, bushings, sways, everything.. Rebuilt 6-port n/a, itb's, prolly microtech lt8, cage..
guessing sm as its still a dd setup I hope :drunken_smilie:
damn sounds like the nice set-up! what was your name again?
for a whole 180 rwhp if you are lucky on a tuned S4 stock port 6 port......
god....
if i put a turbo as amall as fabers on my car it would act like an NA car....... there would be boost all the time, way more than fabers car even
all i am saying is that a rx7 with even just the stock turbo system has waaay more potential than a NA one in anything.... and that he should look into that as it is cheap and very effective
I never said a word about a large frame turbo did i??
I dont care what anybody says.... my car even with a very large turbo is going to beat an NA 7 even in auto-x, not doubt, if the rest of the cars are set up the same, same driver skill
OH and bubba, so you know i pulled a 1.5 60ft without antilag, and i can spool a 42 like a 2jz... hmm
