  3. ICE and Detailing
  4. Amp died
Amp died
29 Posts 10 Posters 5.3k Views
  • civic91C
    civic91C
    civic91
    no best buy and i checked out all the fuses i new of on the amp and took the back panel off to look for anything that looked out of place, looked fine to me but was not sure what i was exactly looking for.
    04 Toyota Celica Gts
    • K
      K
      Ya, sometimes a tiny tiny thing can cause it not work. The crack in the amp I fixed was only visable with a mag. glass.
        Amps CAN die randomly, but usually don't. Next, why would you go to Best Buy to have an amp you already own installed? Go to places that specialize in this stuff like:
        Tintmasters
        Site On Sound
        Team Electronics
        Audio Garage
        Trafik Jamz
        Odds are any of the above places could identify the problem and either fix it themselves or arrange to have the product replaced/repaired.
        • civic91C
          civic91C
          civic91
          i didnt have a wiring kit for an amp in my car yet and my dad want to get it installed for me so it was a b-day present so i didnt really have a choice of where it got installed, but if it was up to me would not have gone there.
          • EvanE
            EvanE
            Evan
            How old is the Amp? What brand? It could be something wrong with your amp kit as well. Amps can die but very unlikely to happen
            bubba;204638 wrote:
            U intelligent..no And I buy all my cars/parts in cash, and bring ur car/camel to the track and we'll see how bad u get owned...
            Past Rides:
            -2003 Dr-Z 125-Sold
            Current Rides:
            • RidinRailsR
              RidinRailsR
              odds are best buy fucked it up...thats not uncommon at all. I've yet to see a car they did in install in that they didnt break some kind of interior piece or screw something up.
              • FG2F
                FG2F
                FG2
                Tintmasters
                Site On Sound
                Team Electronics
                Audio Garage
                Trafik Jamz
                Thanks for the referral Chuck!
                There have been a few instances where the fuse that comes with the power wire is defective from the start. I would replace the fuse (even if it looks good, just spend the $3) in the fuse holder under the hood and see if that helps. I have other suggestions, but before I get to them let me ask you this... does the amp turn on (power light comes on)? Does the amp ever go into 'protection'? How old are the subs? Answer those and we can try a few different things. I'd start with a new fuse up front (again if it looks ok, that doesn't mean anything...It appears the fuse makers are sucking as of lately)...
                • civic91C
                  civic91C
                  civic91
                  It is a phoenix gold subs and amp, never had any probablems with the amp or subs before this. both subs and amp are about 1 1/2 to 2 years old. i have not had time to even mess around with the amp and see if any lights come on. The one thing i dont get is how they said they couldnt get any amp to work(i guess they tried a couple different amps and subs) and then they say that my amp is dead and that was the problem.
                  • FG2F
                    FG2F
                    FG2
                    Well being they tried other amps and it didn't work, then there is more than likely issues elsewhere.
                    1. Fuse for power wire
                      Fix: Replace fuse
                    2. Short inside box with speaker wiring (pos & neg touching)
                      Fix: Remove woofers and make sure all connections are good on terminal cup, and terminals on woofer...make sure no strands of wires are touching
                    3. Short outside box at terminal or amp (pos & neg touching)
                      Fix: Check terminal cup and amplifier to see if any pos and neg wires are touching
                    4. Remote amp turn on wire (blue) not functioning
                      Fix: Test for power on this wire with a multimeter, if no power, remove deck and check connection. If connection is good, you will have to pull switched power from an ignition source.
                    5. Poor ground
                      Fix: Make sure the ground is in a solid piece of metal that is stripped to its bare metal (paint/sealant/etc.. is removed)
                    6. Bad RCA's
                      Fix: Try new RCA's
                    7. Short in voicecoil of woofers
                      Fix: Ohm out each voicecoil of woofer at terminal cup.
                    8. Short in amplifier
                      Fix: Replace 😞
                    Without seeing the amp/vehicle, that is the best I can suggest.
                    • civic91C
                      civic91C
                      civic91
                      subs are good, i would assume the RCA's are good cause they are new but i will just have to try hooking my amp up because they said they did get other amps to work after awhile. thanks for the info/help.
                        I'm willing to put money on one of the solutions that Jason posed being the problem. I'm 99% sure its not the amps since they couldn't get other amps to work either.
                        Which model PG amp is it? I have a few contacts at PG and can at least get you set up for a repair in the off chance that it is the amp.
                          Not a problem, you know I respect the work you guys do there, why would I not acknowledge it on a public forum?
                          • D CaravanD
                            D CaravanD
                            D Caravan
                            Wait so when bestbuy put the new amp in did it work?
                            What kind of amp did bestbuy put it for ya...
                            • civic91C
                              civic91C
                              civic91
                              they told me the amp did not work but the amp did work the last time i used it. also it was a pheonix gold octane amp i think.
                              • D CaravanD
                                D CaravanD
                                D Caravan
                                sup bro
                                  nice first 2 posts D Caravan.....way to ask questions that have nothing to do with solving the problem.
                                  • D CaravanD
                                    D CaravanD
                                    D Caravan
                                    thanks for the welcome....
                                      Fix: Replace fuse
                                    5. Poor ground
                                    6. Bad RCA's
                                      Fix: Try new RCA's
                                      Fix: Replace 😞
                                    and i think my first question was indeed relevant to solving the problem... if the original amp didn't work and all they did was put in a new amp and it worked then it would eliminate many of these suggestions... like the fuse/ground/RCAs and so on
                                    • civic91C
                                      civic91C
                                      civic91
                                      subs and wiring is all good the only thing i was told of that doesnt work is the amp, thought i would clear that up.
                                        Or you could have read the opening paragraph....
                                        civic91;205982 wrote:
                                        so the other weekend i got a amp kit installed into my car, and it took them forever they called while doing this and <u>told me that the subs/amp was not working and that they tried a couple of different amps and that none of those worked either.</u> then later that night i get a call telling me i need to buy a new amp cause mine was dead. <u>the amp worked fine the last time i used this summer and has not been touched until now.</u> i was wondering if an amp could die just randomly when not being used or would the people installing the amp do something to kill it? Have not had time to check if the amp actually does not work.
                                        • D CaravanD
                                          D CaravanD
                                          D Caravan
                                          Ya man exactly, i asked if the subs worked after the new amp was put in... in the first paragraph it say subs/amp... but really its only the amp... my question was legit
                                          I'm new to this forum and was just trying to help out some guy out and this is how you treat me...
