  3. ICE and Detailing
  4. Amp died
Amp died
29 Posts 10 Posters 5.3k Views
  • wesholeW
    wesholeW
    Is Paradise Audio installing it?
    • civic91C
      civic91C
      civic91
      no best buy and i checked out all the fuses i new of on the amp and took the back panel off to look for anything that looked out of place, looked fine to me but was not sure what i was exactly looking for.
      04 Toyota Celica Gts
      • K
        K
        Ya, sometimes a tiny tiny thing can cause it not work. The crack in the amp I fixed was only visable with a mag. glass.
          Amps CAN die randomly, but usually don't. Next, why would you go to Best Buy to have an amp you already own installed? Go to places that specialize in this stuff like:
          Tintmasters
          Site On Sound
          Team Electronics
          Audio Garage
          Trafik Jamz
          Odds are any of the above places could identify the problem and either fix it themselves or arrange to have the product replaced/repaired.
          • civic91C
            civic91C
            civic91
            i didnt have a wiring kit for an amp in my car yet and my dad want to get it installed for me so it was a b-day present so i didnt really have a choice of where it got installed, but if it was up to me would not have gone there.
            • EvanE
              EvanE
              Evan
              How old is the Amp? What brand? It could be something wrong with your amp kit as well. Amps can die but very unlikely to happen
              bubba;204638 wrote:
              U intelligent..no And I buy all my cars/parts in cash, and bring ur car/camel to the track and we'll see how bad u get owned...
              Past Rides:
              -2003 Dr-Z 125-Sold
              Current Rides:
              • RidinRailsR
                RidinRailsR
                odds are best buy fucked it up...thats not uncommon at all. I've yet to see a car they did in install in that they didnt break some kind of interior piece or screw something up.
                • FG2F
                  FG2F
                  FG2
                  Tintmasters
                  Site On Sound
                  Team Electronics
                  Audio Garage
                  Trafik Jamz
                  Thanks for the referral Chuck!
                  There have been a few instances where the fuse that comes with the power wire is defective from the start. I would replace the fuse (even if it looks good, just spend the $3) in the fuse holder under the hood and see if that helps. I have other suggestions, but before I get to them let me ask you this... does the amp turn on (power light comes on)? Does the amp ever go into 'protection'? How old are the subs? Answer those and we can try a few different things. I'd start with a new fuse up front (again if it looks ok, that doesn't mean anything...It appears the fuse makers are sucking as of lately)...
                  • civic91C
                    civic91C
                    civic91
                    It is a phoenix gold subs and amp, never had any probablems with the amp or subs before this. both subs and amp are about 1 1/2 to 2 years old. i have not had time to even mess around with the amp and see if any lights come on. The one thing i dont get is how they said they couldnt get any amp to work(i guess they tried a couple different amps and subs) and then they say that my amp is dead and that was the problem.
                    • FG2F
                      FG2F
                      FG2
                      Well being they tried other amps and it didn't work, then there is more than likely issues elsewhere.
                      1. Fuse for power wire
                        Fix: Replace fuse
                      2. Short inside box with speaker wiring (pos & neg touching)
                        Fix: Remove woofers and make sure all connections are good on terminal cup, and terminals on woofer...make sure no strands of wires are touching
                      3. Short outside box at terminal or amp (pos & neg touching)
                        Fix: Check terminal cup and amplifier to see if any pos and neg wires are touching
                      4. Remote amp turn on wire (blue) not functioning
                        Fix: Test for power on this wire with a multimeter, if no power, remove deck and check connection. If connection is good, you will have to pull switched power from an ignition source.
                      5. Poor ground
                        Fix: Make sure the ground is in a solid piece of metal that is stripped to its bare metal (paint/sealant/etc.. is removed)
                      6. Bad RCA's
                        Fix: Try new RCA's
                      7. Short in voicecoil of woofers
                        Fix: Ohm out each voicecoil of woofer at terminal cup.
                      8. Short in amplifier
                        Fix: Replace 😞
                      Without seeing the amp/vehicle, that is the best I can suggest.
                      • civic91C
                        civic91C
                        civic91
                        subs are good, i would assume the RCA's are good cause they are new but i will just have to try hooking my amp up because they said they did get other amps to work after awhile. thanks for the info/help.
                          I'm willing to put money on one of the solutions that Jason posed being the problem. I'm 99% sure its not the amps since they couldn't get other amps to work either.
                          Which model PG amp is it? I have a few contacts at PG and can at least get you set up for a repair in the off chance that it is the amp.
                            Not a problem, you know I respect the work you guys do there, why would I not acknowledge it on a public forum?
                            • D CaravanD
                              D CaravanD
                              D Caravan
                              Wait so when bestbuy put the new amp in did it work?
                              What kind of amp did bestbuy put it for ya...
                              • civic91C
                                civic91C
                                civic91
                                they told me the amp did not work but the amp did work the last time i used it. also it was a pheonix gold octane amp i think.
                                • D CaravanD
                                  D CaravanD
                                  D Caravan
                                  sup bro
                                    nice first 2 posts D Caravan.....way to ask questions that have nothing to do with solving the problem.
                                    • D CaravanD
                                      D CaravanD
                                      D Caravan
                                      thanks for the welcome....
                                        Fix: Replace fuse
                                      5. Poor ground
                                      6. Bad RCA's
                                        Fix: Try new RCA's
                                        Fix: Replace 😞
                                      and i think my first question was indeed relevant to solving the problem... if the original amp didn't work and all they did was put in a new amp and it worked then it would eliminate many of these suggestions... like the fuse/ground/RCAs and so on
                                      • civic91C
                                        civic91C
                                        civic91
                                        subs and wiring is all good the only thing i was told of that doesnt work is the amp, thought i would clear that up.
                                          Or you could have read the opening paragraph....
                                          civic91;205982 wrote:
                                          so the other weekend i got a amp kit installed into my car, and it took them forever they called while doing this and <u>told me that the subs/amp was not working and that they tried a couple of different amps and that none of those worked either.</u> then later that night i get a call telling me i need to buy a new amp cause mine was dead. <u>the amp worked fine the last time i used this summer and has not been touched until now.</u> i was wondering if an amp could die just randomly when not being used or would the people installing the amp do something to kill it? Have not had time to check if the amp actually does not work.
