Amp died
I'm willing to put money on one of the solutions that Jason posed being the problem. I'm 99% sure its not the amps since they couldn't get other amps to work either.
Which model PG amp is it? I have a few contacts at PG and can at least get you set up for a repair in the off chance that it is the amp.
tjamz;206584 wrote:
nice first 2 posts D Caravan.....way to ask questions that have nothing to do with solving the problem.
thanks for the welcome....FG2;206326 wrote:
Well being they tried other amps and it didn't work, then there is more than likely issues elsewhere.- Fuse for power wire
Fix: Replace fuse - Short inside box with speaker wiring (pos & neg touching)
Fix: Remove woofers and make sure all connections are good on terminal cup, and terminals on woofer...make sure no strands of wires are touching - Short outside box at terminal or amp (pos & neg touching)
Fix: Check terminal cup and amplifier to see if any pos and neg wires are touching - Remote amp turn on wire (blue) not functioning
Fix: Test for power on this wire with a multimeter, if no power, remove deck and check connection. If connection is good, you will have to pull switched power from an ignition source. - Poor ground
Fix: Make sure the ground is in a solid piece of metal that is stripped to its bare metal (paint/sealant/etc.. is removed) - Bad RCA's
Fix: Try new RCA's - Short in voicecoil of woofers
Fix: Ohm out each voicecoil of woofer at terminal cup. - Short in amplifier
Fix: Replace
Without seeing the amp/vehicle, that is the best I can suggest.
and i think my first question was indeed relevant to solving the problem... if the original amp didn't work and all they did was put in a new amp and it worked then it would eliminate many of these suggestions... like the fuse/ground/RCAs and so on
D Caravan;206588 wrote:
and i think my first question was indeed relevant to solving the problem... if the original amp didn't work and all they did was put in a new amp and it worked then it would eliminate many of these suggestions... like the fuse/ground/RCAs and so onOr you could have read the opening paragraph....
civic91;205982 wrote:
so the other weekend i got a amp kit installed into my car, and it took them forever they called while doing this and <u>told me that the subs/amp was not working and that they tried a couple of different amps and that none of those worked either.</u> then later that night i get a call telling me i need to buy a new amp cause mine was dead. <u>the amp worked fine the last time i used this summer and has not been touched until now.</u> i was wondering if an amp could die just randomly when not being used or would the people installing the amp do something to kill it? Have not had time to check if the amp actually does not work. -
Ya man exactly, i asked if the subs worked after the new amp was put in... in the first paragraph it say subs/amp... but really its only the amp... my question was legit
I'm new to this forum and was just trying to help out some guy out and this is how you treat me...
D Caravan;206620 wrote:
Ya man exactly, i asked if the subs worked after the new amp was put in...You did?
D Caravan;206556 wrote:
Wait so when bestbuy put the new amp in did it work?in the first paragraph it say subs/amp... but really its only the amp... my question was legit
I'll give you that, but nothing you asked would have helped beyond what Jason (FG2) already suggested, so, while "legit", it was redundant as it was posted in the original post already that the amp worked before (last summer) and that then was the last time the amp was used.
Welcome to the internet, if you have something useful to contribute we'll all be happy to listen, if you ask dumb questions (especially those that have already been answered) expect to be flamed.
And please tell me how a post whose only words were > D Caravan;206575 wrote:
sup bro is going to help solve the problem.
In short: Reading Comprehension > You and welcome to Fargostreet.
Also, yes, I am always a dick.
so what brand subs and amp is it, did you check the ground.. maybe try other amps? lol just for chuck
