  4. 12 injector setup
12 injector setup
16 Posts 10 Posters 2.0k Views
    Bungs are on the bottom of the runners, just waiting to be filled with injectors. Should get the plumbing done this weekend and then we'll have enough fuel injector to run alcohol. 🙂
    • 01tib0 Offline
      01tib0 Offline
      01tib
      Dayum... just a little bit of fuel (or alcohol) will be flowin through these...
      <u>Cars</u>
      93 Civic EX - Ghetto B16A/GSR swapped - <u>SOLD</u>
      **01 Tiburon ** - <u>For Sale</u>
        Fuck the gas crunch I say... Looks good and...... unefficent Dave.
          so in your opinion dave/matt what is the straight alcohol going to do for charge temps vs gas??
          do you think a charge cooler is required with alcohol?? or will you just leave the air:air on matt's car cuz it is there already
          anyway, lots of fuel 🙂
            Not really sure how much the charge temps are going to lower with the alcohol, from what you read it should be quite a bit. We are both keeping our intercoolers, altho I might lose the h2o/water and replace it with an air/air for next year. It's too much work to start that change this year.
            • Sweet-WRX-LovinS Offline
              Sweet-WRX-Lovin
              Damn nice craftmanship on that intake. Where does the "Danger to Manifold" sensor go?
              One time...
                Running straight E98 you really dont need the intercooler. I have watched quite a few cars setup with methanol and ethanol, and on cool days the intake will frost up. This is very common on carbed setups, hell they dont even run cooling systems on methanol cars, thats how cold they run. I personally think you would be better off ditching the IC and its weight and effect on spool. The weight break off the nose would offset any gains i think
                • fallguyF Offline
                  fallguyF Offline
                  fallguy
                  Actually I'm filling my block, so the cooling effect will be helpful when I drive around on the street. 🙂 I think the IC will help cooling on really hot days at the track and keep the temps down when we run 45+ lbs of boost.
                  1990 Ford Probe GT 2jz RWD
                    Filled block alcohol burning back halved cars are NOT street cars Matt. I don't know if you got the memo or not hahahaha.
                    • fallguyF Offline
                      fallguyF Offline
                      fallguy
                      E98 ethanol...just trying to be "green" and doing my part to save the planet. 🙂 It's all in the mind of the beholder. 😉
                        Ah. That's a very liberal thing of you to do. 🙂
                          Looks like a braided line factory exploded under the hood...
                            Rice!!! Nah, i looks sweet.
                              I say throw 6 more on there...how many cars you see running around w/ tertiary injectors for when the secondaries run out?
                                looks good guys :icon_thumleft:
                                • M Offline
                                  M Offline
                                  musthavemuzk
                                  so are these drag cars or show cars?
                                  cannot believe how clean those bad boys are.
                                  Props to ya.
                                  Monty
                                  14.59 at 94.85 still stock
                                  www.pbase.com/musthavemuzk
