  3. Run Your Mouth
  4. My Improperly set welder...
39 Posts 13 Posters 4.8k Views
    itRfan;211977 wrote:
    Damn i was the only one said nice welds to joel and i STILL didnt get a thank you??? Well the hell with that...joel your welds suck ass!!! jk
    Thanks...
      ok now to bring some drama back into this thread....
      Zac, your tig welds suck balls.
      :faq-roll:
        DelSlow;211940 wrote:
        who gives a shit...really.
        Exactly...that's why i put the smilie I did...no one cares...joel just cant let shit go, as i'm sure everyone has been able to tell by now....
        • Afsil80A Offline
          Afsil80A Offline
          Afsil80
          Just remember, God REALLY invented heat wrap to cover up bad welds...
          EDIT: Huge turbos are also good distractions.
          -Peter
          1991 240SX
            And neither can you guys...
            It is the pot calling the kettle black here. You do the same shit that you complain about Joel doing...
              prove it
                QFTMFT
                • Afsil80A Offline
                  Afsil80A Offline
                  Afsil80
                  Parker;212046 wrote:
                  prove it
                  Prove what, that there's ugly welds beneath that heat wrap? That's why we did it, hahaha. It was the only Pro Hot Rod car with heat wrap this weekend.
                  The manifold holds up fine, it just doesn't look the best, haha.
                  -Peter
                  1991 240SX
                    no prove that god invented heat wrap... you silly...
                      He is from the south, whattya expect?
                        :faq-roll:
                        stupid not to suck a ball or two once in awhile :drooling:
                        • FG2F Offline
                          FG2F Offline
                          FG2
                          Here is my question. I know nothing about blonde asian women, baseball, or welding. Even though Joel's welding yields some jizzum splatter, does it effect the strength of the weld? For the flange on the downpipe, would a 'non jizzum splatter' weld offer the extra NEEDED strength, or would it be ok? I ask in all seriousness, cause besides not being the most attractive, I don't see why it wouldn't do the task... Again, I am a welding noob and have utmost respect to anyone that can make a straight bead.
                            ^From my understanding, it is more that the machine was not set up properly for the welding that it was used for. The splatter is material that could have been part of the weld. For the exhaust welding, its not a problem, I have seen MUCH worse work from local exhuast shops.
                              It had to do with the fact that I had only 700 PSI of gas left, and I was at the end of a small spool of wire(meaning the wire comes out of the tip of the gun very unevenly.) Settings had nothing to do with it, otherwise the weld itseld would look like shit.
                                i did those welds on with the remainder of the wire and a diff tank of gas that had only 500ish psi left.... i just played around with the wire speed a bit.... and i am no MIG welder....
                                  Troof, I was there
                                    Joel;212205 wrote:
                                    It had to do with the fact that I had only 700 PSI of gas left, .
                                    LOL are you serious???? really now are you serious??
                                    drrrrrrrrrrrrrr hhmmmmm that flow meter next to the cylinder pressure gauge does nothing
                                    a cylinder with with only 300psi left is going to hold a steady CFH of gas flow.... it will stay consistent and not fall off till it cannot the support the level of gas flow you are asking for........... which is far far south of 700psi
                                    lol god that is fucking funny...... we change all our $70 worth of shielding gas out when it gets below 1000psi because it makes my welds look like dog shit
                                    I thought you go to NDSU........... pay more attention in the fluid/gas dynamics section of your physics class
                                      +1.. I could see if there's a diff psi flowing, but amount left shouldnt matter, as long as it comes out at the same rate...
                                        So i made a weld with some fucking spatter. OMFG, Lets die. I made a shitty weld, does that make you guys happy. Now get over it.
                                          Ur the one that brought up another whole thread about it, cuz u couldnt let it go....
