  4. rotarys what??
rotarys what??
28 Posts 13 Posters 4.8k Views
  • slow90gsxS Offline
    slow90gsxS Offline
    slow90gsx
    how long till thats laying on the ground in pieces.......
      16 1/2 Feet
        all it takes is for the car to wheel hop once.... then kaboom....
          slow90gsxS Offline
          slow90gsx
          what are you going to replace it with?
            ford 8.8'' or 9''
              squawsnatch
              zac..................if only the noobs knew what the stock na rear end was capable of.
                9.4 @ 140+???
                I fibbed a bit, that was completely stock TII diff, axles, suspension....
                I know of NA rears in low 10s though
                  zbrown;222297 wrote:
                  9.4 @ 140+???
                  lol... thats the solid axle under that... n00b..
                    lol @ u.... im pretty sure i of all people here knows what the staock n/a rear diff is good too... its good to the tens, yes... But... wheel hop is the enemy in most cases
                      hmmmm...
                      looks to me like the wheels are toed in big time........ how does that happen on a solid axe....
                      parker = noob
                      and that car DID do a 9.40 @ 142 on a stock TII rear, halfshafts, and suspension.....
                      it is backhalved now yes
                        zbrown;222307 wrote:
                        hmmmm...
                        parker = noob
                        Speaking of N00bs, it's not "toe" that your looking at there is camber my friend. And it is definately showing negative camber. Indicative of an independent rear suspension.
                          pwnd
                          • jdm-az-yoJ Offline
                            jdm-az-yoJ Offline
                            jdm-az-yo
                            +1 for slow sauce haha jk
                              hmmmm...
                              parker = noob
                              lol... thats katorx7's car (v8rx7forum)... and that pass in the picture was done on a granny's solid axle kit.. you are basing the front to the rear... just looks like a solid axle too me..
                                thanks for keeping me in line 🙂
                                • z31Z Offline
                                  z31Z Offline
                                  z31
                                  That is not a solid rear axle, unless it's bent. :icon_scratch:
                                  IRS can hold a lot of power. http://www.youtube.com/watch?v=mf4R0Ba_zHQ
                                    lol... that does not look like an rx7 with a 7'' ring gear...
                                    and yes... the rear looks like its cambering in... if you compare it to the <u>front, that is about ready to lift</u>... but prove me wrong.. run a 9 second pass on a 7'' ring gear and shut me up:icon_cheers:
                                    • Afsil80A Offline
                                      Afsil80A Offline
                                      Afsil80
                                      The REAL question:
                                      How many N/A rear ends will you go through before you decide to go with something different? 😉
                                      -Peter
                                      1991 240SX
                                        Afsil80;222510 wrote:
                                        The REAL question:
                                        hopefuly none
