  4. rotarys what??
rotarys what??
28 Posts 13 Posters 5.1k Views
    squawsnatch
    zac..................if only the noobs knew what the stock na rear end was capable of.
      9.4 @ 140+???
      I fibbed a bit, that was completely stock TII diff, axles, suspension....
      I know of NA rears in low 10s though
        zbrown;222297 wrote:
        9.4 @ 140+???
        lol... thats the solid axle under that... n00b..
          lol @ u.... im pretty sure i of all people here knows what the staock n/a rear diff is good too... its good to the tens, yes... But... wheel hop is the enemy in most cases
            hmmmm...
            looks to me like the wheels are toed in big time........ how does that happen on a solid axe....
            parker = noob
            and that car DID do a 9.40 @ 142 on a stock TII rear, halfshafts, and suspension.....
            it is backhalved now yes
              zbrown;222307 wrote:
              hmmmm...
              parker = noob
              Speaking of N00bs, it's not "toe" that your looking at there is camber my friend. And it is definately showing negative camber. Indicative of an independent rear suspension.
                pwnd
                • jdm-az-yoJ Offline
                  jdm-az-yoJ Offline
                  jdm-az-yo
                  +1 for slow sauce haha jk
                    hmmmm...
                    parker = noob
                    lol... thats katorx7's car (v8rx7forum)... and that pass in the picture was done on a granny's solid axle kit.. you are basing the front to the rear... just looks like a solid axle too me..
                      thanks for keeping me in line 🙂
                      • z31Z Offline
                        z31Z Offline
                        z31
                        That is not a solid rear axle, unless it's bent. :icon_scratch:
                        IRS can hold a lot of power. http://www.youtube.com/watch?v=mf4R0Ba_zHQ
                          lol... that does not look like an rx7 with a 7'' ring gear...
                          and yes... the rear looks like its cambering in... if you compare it to the <u>front, that is about ready to lift</u>... but prove me wrong.. run a 9 second pass on a 7'' ring gear and shut me up:icon_cheers:
                          • Afsil80A Offline
                            Afsil80A Offline
                            Afsil80
                            The REAL question:
                            How many N/A rear ends will you go through before you decide to go with something different? 😉
                            -Peter
                            1991 240SX
                              Afsil80;222510 wrote:
                              The REAL question:
                              hopefuly none
