rotarys what??
zac..................if only the noobs knew what the stock na rear end was capable of.
lol @ u.... im pretty sure i of all people here knows what the staock n/a rear diff is good too... its good to the tens, yes... But... wheel hop is the enemy in most cases -
Parker;222299 wrote:
lol... thats the solid axle under that... n00b..hmmmm...
looks to me like the wheels are toed in big time........ how does that happen on a solid axe....
parker = noob
and that car DID do a 9.40 @ 142 on a stock TII rear, halfshafts, and suspension.....
it is backhalved now yes
zbrown;222307 wrote:
hmmmm...looks to me like the wheels are toed in big time........ how does that happen on a solid axe....
parker = noob
Speaking of N00bs, it's not "toe" that your looking at there is camber my friend. And it is definately showing negative camber. Indicative of an independent rear suspension.
weshole;222309 wrote:
Speaking of N00bs, it's not "toe" that your looking at there is camber my friend. And it is definately showing negative camber.pwnd
parker = noob
lol... thats katorx7's car (v8rx7forum)... and that pass in the picture was done on a granny's solid axle kit.. you are basing the front to the rear... just looks like a solid axle too me.. -
That is not a solid rear axle, unless it's bent. :icon_scratch:
IRS can hold a lot of power. http://www.youtube.com/watch?v=mf4R0Ba_zHQ
z31;222418 wrote:
That is not a solid rear axle, unless it's bent. :icon_scratch:IRS can hold a lot of power. http://www.youtube.com/watch?v=mf4R0Ba_zHQ
lol... that does not look like an rx7 with a 7'' ring gear...and yes... the rear looks like its cambering in... if you compare it to the <u>front, that is about ready to lift</u>... but prove me wrong.. run a 9 second pass on a 7'' ring gear and shut me up:icon_cheers:
