  3. Wanted Ads
  4. WTB: Injector box and map sensor
13 Posts 4 Posters 882 Views
  • BlackEJ8B Offline
    BlackEJ8B Offline
    BlackEJ8
    Well my car is FINALLY boosted and I just need these two things before I get tuned.
    Injector resistor box with the clips
    3 bar map sensor
    Honda Civic Si - Daily
      Go to radioshack and ask for 4 10ohm, 10watt resistors, and wire them inline. Very simple and costs about $4.
        very true and you can hid them up by where you would install the resistor box still for a clean install.
        • gsrEKG Offline
          gsrEKG Offline
          gsrEK
          WORD thanks again
          2009 Yamaha Zuma 125, gas HOG
          2008 Honda Fit daily
          A s2k
          1991 Honda civic DX Mint SOLD
          1988 Mitsubishi Mighty max
          > BlackEJ8;233529 wrote:
            lawlski
            • BlackEJ8B Offline
              BlackEJ8B Offline
              BlackEJ8
              what should i do about the clips?
                i can show you how to modify them but its really easy. just cut off a tab on your factory clips and they will work with like any injector
                  I do the inline resistors under the intake manifold so they can't be seen. And for injectors, i always just take a utility knife and cut out the one little tab on the inside part of where the clip goes and cut that off, then stock clips slip right on.
                    exactly^
                    • BlackEJ8B Offline
                      BlackEJ8B Offline
                      BlackEJ8
                      thanks guys!!
                        yup.. when you say its finally boosted... youre not driving it on the factory injectors/tune are you???
                        • BlackEJ8B Offline
                          BlackEJ8B Offline
                          BlackEJ8
                          Haha actually I have driven it, but not going over 2500 and also there is a section of IC piping out to make sure it doesnt create boost.
                            alrighty. just make sure
