  3. Wanted Ads
  4. WTB: Injector box and map sensor
13 Posts 4 Posters 1.0k Views
    very true and you can hid them up by where you would install the resistor box still for a clean install.
    • gsrEKG Offline
      gsrEKG Offline
      gsrEK
      WORD thanks again
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
      > BlackEJ8;233529 wrote:
        lawlski
        • BlackEJ8B Offline
          BlackEJ8B Offline
          BlackEJ8
          what should i do about the clips?
          Honda Civic Si - Daily
            i can show you how to modify them but its really easy. just cut off a tab on your factory clips and they will work with like any injector
              I do the inline resistors under the intake manifold so they can't be seen. And for injectors, i always just take a utility knife and cut out the one little tab on the inside part of where the clip goes and cut that off, then stock clips slip right on.
                exactly^
                • BlackEJ8B Offline
                  BlackEJ8B Offline
                  BlackEJ8
                  thanks guys!!
                    yup.. when you say its finally boosted... youre not driving it on the factory injectors/tune are you???
                    • BlackEJ8B Offline
                      BlackEJ8B Offline
                      BlackEJ8
                      Haha actually I have driven it, but not going over 2500 and also there is a section of IC piping out to make sure it doesnt create boost.
                        alrighty. just make sure
