WTB: Injector box and map sensor
Go to radioshack and ask for 4 10ohm, 10watt resistors, and wire them inline. Very simple and costs about $4.
very true and you can hid them up by where you would install the resistor box still for a clean install.
lawlski
i can show you how to modify them but its really easy. just cut off a tab on your factory clips and they will work with like any injector
I do the inline resistors under the intake manifold so they can't be seen. And for injectors, i always just take a utility knife and cut out the one little tab on the inside part of where the clip goes and cut that off, then stock clips slip right on.
exactly^
yup.. when you say its finally boosted... youre not driving it on the factory injectors/tune are you???
alrighty. just make sure
