  3. Wanted Ads
  4. Want to borrow- engine hoist and tranny jack
13 Posts 5 Posters 817 Views
  • fdfreakF Offline
    fdfreakF Offline
    fdfreak
    Hey guys, here in about 2 weeks I am taking my car apart and need a few tools. All i need is an engine hoist and a transmission jack. to rent these from Rent-All would cost me over $100. So just seeing if anyone would be willing to loan me theirs for a day. Willing to pay for use of the equipment.
    thanks
    Aaron
    12.645@118mph 12.6psi
    • 2wheeler2 Offline
      2wheeler2 Offline
      2wheeler
      I have a hoist for ya.
      Ethan
      701.367.4555
      '08 Suzuki Hayabusa
      '09 Yamaha Zuma 200cc
      '95 E-350 7.5L
      • F Offline
        F Offline
        fanaticrockford
        I have a hoist as well.
        • fdfreakF Offline
          fdfreakF Offline
          fdfreak
          max said that he has a hoist too. now how about a transmission jack? looking to borrow the weekend of the 27,28 of sept.
            why do you need a transmission jack?? one person can handle those trannys... with two it is cake.
            It is would be easiest to pull/install the engine with the tranny attached
              ^I am with him.
              I have a tranny jack, but will be out of town all weekend.
              • fdfreakF Offline
                fdfreakF Offline
                fdfreak
                I dont think its possible to pull the engine out with the tranny on the FD's. Its hard enough pulling them out with just the downpipe on. you have to take the tranny off before pulling the engine. Unless someone has done it, please enlighten me but even of rx7club, i have never heard of anyone doing it. If you have suggestions, i am all ears. and your right zack, it is easy taking the tranny out. I forgot how light they are. its putting in the tranny thats the hard part.
                • F Offline
                  F Offline
                  fanaticrockford
                  http://fargo.craigslist.org/tls/840286006.html
                  • fdfreakF Offline
                    fdfreakF Offline
                    fdfreak
                    its been deleted. I dont want to buy one because I live it a condo and I have no room for cherry picker.
                    • F Offline
                      F Offline
                      fanaticrockford
                      That was a trans jack for $35 that was only used once but they must have sold it.
                        I think definitely would be easier with tranny attached.....
                        Remember that if you split the engine from the car in a FD that they use a pull type clutch not a push.... so you need to release the throw-out bearing before it will come apart..
                        Should come out just as easy as a FC... only thing more a FD would have is the PPF, (Power Plant Frame) at the ass of the tranny
                        here is a link from kevin landers..... didn't look at it but should cover everything...
                        http://www.rotaryresurrection.com/3rdgen/tech_93eng_remov.html
                        • fdfreakF Offline
                          fdfreakF Offline
                          fdfreak
                          no shit. Thanks for that. When I took the tranny off before, i just took the 8 bolts off that connectedt he clutch plate to the flywheel. The FD's had a access panel to them.
                          But this looks way easier.
                            ha no problem...
                            unbolting the pressure plate from the flywheel can't be correct procedure, but what works works 🙂
                            good luck
