  4. I'll be using the Chute more often
20 Posts 12 Posters 972 Views
  • XJHEADX Offline
    XJHEADX Offline
      Ooo damn , forget that just put it in second and compression brake
      • z31Z Offline
        z31Z Offline
        z31
        Why?
        Just weld up the cracks:icon_geek:
        • kylushK Offline
          kylushK Offline
          kylush
          screw that just use jb weld
          1998 Z28 Camaro
            just pop it in reverse. You'll stop
              So far none of these ideas are cost effective, my idea is free
                WIN
                  Needs a "jake" brake.
                    Nice crack.
                    • XJHEADX Offline
                      XJHEADX Offline
                      I was thinking more of a tailhook.
                      • J Offline
                        J Offline
                        jklm541
                          DIY slotted rotors?
                          • XJHEADX Offline
                            XJHEADX Offline
                            Parker;238167 wrote:
                            DIY slotted rotors?
                            Are you asking if those were DIY's?? If so, no they were not..
                            • G Offline
                              G Offline
                              generation_xxx
                              what brand are they. is it me or does it seem like the pads are only covering 3/4's the surface they should be.
                                generation_xxx;238190 wrote:
                                what brand are they. Is it me or does it seem like the pads are only covering 3/4's the surface they should be.
                                looks to me like the pad is covering almost the entire surface, the center just looks like it got really hot
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  I am sure they are just slotted stockers. That is the way they are designed from Ford. The brakes work good, obviously too good.
                                  • D S ohMD Offline
                                    D S ohMD Offline
                                    D S ohM
                                    Holy damn dude. I like the pop it in reverse idea...that usually works.
                                    I wanna go fast!
                                      Usually? Always, 60% of the time everytime
                                        e-sarcasim?
                                        no?
                                          Time for lightweight big brake upgrade??
