  4. I'll be using the Chute more often
20 Posts 12 Posters 1.1k Views
    DelSlow;237976 wrote:
    just pop it in reverse. You'll stop
    WIN
      Needs a "jake" brake.
        Nice crack.
        • XJHEADX Offline
          XJHEADX Offline
          I was thinking more of a tailhook.
          • J Offline
            J Offline
            jklm541
              DIY slotted rotors?
              • XJHEADX Offline
                XJHEADX Offline
                Parker;238167 wrote:
                DIY slotted rotors?
                Are you asking if those were DIY's?? If so, no they were not..
                • G Offline
                  G Offline
                  generation_xxx
                  what brand are they. is it me or does it seem like the pads are only covering 3/4's the surface they should be.
                    generation_xxx;238190 wrote:
                    what brand are they. Is it me or does it seem like the pads are only covering 3/4's the surface they should be.
                    looks to me like the pad is covering almost the entire surface, the center just looks like it got really hot
                    • XJHEADX Offline
                      XJHEADX Offline
                      I am sure they are just slotted stockers. That is the way they are designed from Ford. The brakes work good, obviously too good.
                      • D S ohMD Offline
                        D S ohMD Offline
                        D S ohM
                        Holy damn dude. I like the pop it in reverse idea...that usually works.
                        I wanna go fast!
                          Usually? Always, 60% of the time everytime
                            e-sarcasim?
                            no?
                              Time for lightweight big brake upgrade??
