  4. I'll be using the Chute more often
20 Posts 12 Posters 1.2k Views
  • kylushK Offline
    kylushK Offline
    kylush
    screw that just use jb weld
    1998 Z28 Camaro
      just pop it in reverse. You'll stop
        So far none of these ideas are cost effective, my idea is free
          WIN
            Needs a "jake" brake.
              Nice crack.
              • XJHEADX Offline
                XJHEADX Offline
                I was thinking more of a tailhook.
                • J Offline
                  J Offline
                  jklm541
                    DIY slotted rotors?
                    • XJHEADX Offline
                      XJHEADX Offline
                      Parker;238167 wrote:
                      DIY slotted rotors?
                      Are you asking if those were DIY's?? If so, no they were not..
                      • G Offline
                        G Offline
                        generation_xxx
                        what brand are they. is it me or does it seem like the pads are only covering 3/4's the surface they should be.
                          generation_xxx;238190 wrote:
                          what brand are they. Is it me or does it seem like the pads are only covering 3/4's the surface they should be.
                          looks to me like the pad is covering almost the entire surface, the center just looks like it got really hot
                          • XJHEADX Offline
                            XJHEADX Offline
                            I am sure they are just slotted stockers. That is the way they are designed from Ford. The brakes work good, obviously too good.
                            • D S ohMD Offline
                              D S ohMD Offline
                              D S ohM
                              Holy damn dude. I like the pop it in reverse idea...that usually works.
                              I wanna go fast!
                                Usually? Always, 60% of the time everytime
                                  e-sarcasim?
                                  no?
                                    Time for lightweight big brake upgrade??
