  4. issues boosting
issues boosting
42 Posts 10 Posters 2.5k Views
  • JoelJ
    JoelJ
    ur car sucks bryan, face it OSOSLOW!
    • 9
      9
      92TSIpos
      and whos car is still sitting in the shop NOT RUNNING 😛
      • SmitEvoS
        SmitEvoS
        check for boost leaks.
        kevin
        sls
        • 9
          9
          92TSIpos
          kevin
          sls
          where are common places for leaks
          • SmitEvoS
            SmitEvoS
            well check :
            Turbo J pipe
            Lower ic hose/pipe
            Intercooler
            Upper ic pipe
            Tb
            Vac lines
            Bov
            Kevin
            sls
            • 9
              9
              92TSIpos
              will have to look at it tomorrow, prolly make something like what nick has to check for boost leaks.
              • JimJ
                JimJ
                I think he means check your intercooler piping, couplers, clamps etc...
                • 9
                  9
                  92TSIpos
                  I know what he meant. thats prolly the only thing that actually does leak.
                  • JimJ
                    JimJ
                    Why would you need to build something? Just tighten them all down and such
                    • 9
                      9
                      92TSIpos
                      oh i know but i think its a little more extensive than just ic piping or couplers, so i think it will save a lot of headaches to just throw something together real quick to check for boost leaks.
                      • -GSX-Falcon-
                        -GSX-Falcon-
                        -GSX-Falcon
                        Im assuming hes making something so he can pressurize the system and locate where the leak is coming from. It usually is the piping but it may be something he cant see/tighten. Like a tiny hole in a lower pipe or something.
                        92 GSX Automatic -Manual Cams, Injectors, ECU -Big 16g -Turboback Exh -Ported Evo Manifold -Ported 2g o2 -MBC -JDM 4g63 -Walbro 190 -3" Intake
                        • 9
                          9
                          92TSIpos
                          thanks alot for clearing that up for me, i wasnt sure if he knew what i meant by "building something".
                          • JimJ
                            JimJ
                            I knew what what you meant, but it seems like a waste of time to do something like that right off the bat... which it sounded like you were going to do... if all it was was a loose clamp, loose bov or something
                            • 9
                              9
                              92TSIpos
                              Yeah i guess that would suck. I will prolly check everything over, and if anything else go to plan B.
                              • 9
                                9
                                92TSIpos
                                right now im not even sure if its a boost leak. I should say screw it and bring it to kevin and have him check it out if i cant find anything.
                                • SmitEvoS
                                  SmitEvoS
                                  lol good one jim!!
                                  Kevin
                                  • JimJ
                                    JimJ
                                    your welcome lol
                                    • 9
                                      9
                                      92TSIpos
                                      if what i described is not a boost leak than what else could it be?
                                      • King RicerK
                                        King RicerK
                                        the fact that you let max touch your car and help you do stuff to it might be the problem. j/k
                                        Trafik Jamz;299122 wrote:
                                        • O
                                          O
                                          have you gotten a second opinion on how the car feels under boost? it might not be anything because you're so used to how it feels. as far as the sputtering... without konwing anything else about the problem, i'm going to guess that you're getting too much fuel somewhere
