issues boosting
Im assuming hes making something so he can pressurize the system and locate where the leak is coming from. It usually is the piping but it may be something he cant see/tighten. Like a tiny hole in a lower pipe or something.
-GSX-Falcon wrote:
Im assuming hes making something so he can pressurize the system and locate where the leak is coming from. It usually is the piping but it may be something he cant see/tighten. Like a tiny hole in a lower pipe or something.thanks alot for clearing that up for me, i wasnt sure if he knew what i meant by "building something".
Jim wrote:
I knew what what you meant, but it seems like a waste of time to do something like that right off the bat... which it sounded like you were going to do... if all it was was a loose clamp, loose bov or somethingYeah i guess that would suck. I will prolly check everything over, and if anything else go to plan B.
the fact that you let max touch your car and help you do stuff to it might be the problem. j/k
have you gotten a second opinion on how the car feels under boost? it might not be anything because you're so used to how it feels. as far as the sputtering... without konwing anything else about the problem, i'm going to guess that you're getting too much fuel somewhere
