  4. issues boosting
issues boosting
42 Posts 10 Posters 1.6k Views
  • 9 Offline
    9 Offline
    92TSIpos
    I have a 92 talon tsi and i just got the new motor in, and it wont boost past ten pounds without the car sputtering. It feels like the car has no pull when the turbo spools. I cant figure it out. please help.
      ur car sucks bryan, face it OSOSLOW!
      • 9 Offline
        9 Offline
        92TSIpos
        and whos car is still sitting in the shop NOT RUNNING 😛
          check for boost leaks.
          kevin
          sls
          • 9 Offline
            9 Offline
            92TSIpos
            kevin
            sls
            where are common places for leaks
              well check :
              Turbo J pipe
              Lower ic hose/pipe
              Intercooler
              Upper ic pipe
              Tb
              Vac lines
              Bov
              Kevin
              sls
              • 9 Offline
                9 Offline
                92TSIpos
                will have to look at it tomorrow, prolly make something like what nick has to check for boost leaks.
                  I think he means check your intercooler piping, couplers, clamps etc...
                  • 9 Offline
                    9 Offline
                    92TSIpos
                    I know what he meant. thats prolly the only thing that actually does leak.
                      Why would you need to build something? Just tighten them all down and such
                      • 9 Offline
                        9 Offline
                        92TSIpos
                        oh i know but i think its a little more extensive than just ic piping or couplers, so i think it will save a lot of headaches to just throw something together real quick to check for boost leaks.
                        • -GSX-Falcon- Offline
                          -GSX-Falcon
                          Im assuming hes making something so he can pressurize the system and locate where the leak is coming from. It usually is the piping but it may be something he cant see/tighten. Like a tiny hole in a lower pipe or something.
                          92 GSX Automatic -Manual Cams, Injectors, ECU -Big 16g -Turboback Exh -Ported Evo Manifold -Ported 2g o2 -MBC -JDM 4g63 -Walbro 190 -3" Intake
                          • 9 Offline
                            9 Offline
                            92TSIpos
                            thanks alot for clearing that up for me, i wasnt sure if he knew what i meant by "building something".
                              I knew what what you meant, but it seems like a waste of time to do something like that right off the bat... which it sounded like you were going to do... if all it was was a loose clamp, loose bov or something
                              • 9 Offline
                                9 Offline
                                92TSIpos
                                Yeah i guess that would suck. I will prolly check everything over, and if anything else go to plan B.
                                • 9 Offline
                                  9 Offline
                                  92TSIpos
                                  right now im not even sure if its a boost leak. I should say screw it and bring it to kevin and have him check it out if i cant find anything.
                                    lol good one jim!!
                                    Kevin
                                      your welcome lol
                                      • 9 Offline
                                        9 Offline
                                        92TSIpos
                                        if what i described is not a boost leak than what else could it be?
                                          the fact that you let max touch your car and help you do stuff to it might be the problem. j/k
