  3. Events
  4. Dyno in fargo Jan 8 & 9
134 Posts 35 Posters 9.4k Views
  • Pony_RacerP Offline
    Pony_RacerP Offline
    Pony_Racer
    sweet #'s on all the runs....now wheres that video 😄
    R.I.P 1QK_PNY:icon_salut:
      Video is in the media section. Thanks Jim for hosting it, and thx to wannabe for taping it.
        http://www.fargostreet.com/temp/video/davehenry.wmv
        I did a little editing (thx for vid wannabe)
          you and your fancy video editing
          • My NOvaM Offline
            My NOvaM Offline
            My NOva
            what program did u use therejim??? and does he have a vid of it with nos???
            Hey Tina come get some hamm
              He didn't run n2o that I'm aware of. It's fricken hilarious. A under 600 pony supra is running faster times than supra's upwards of 900 horse. Way to go Dave!
                Cool. I did the swap in that civic hatch. Nice to see that he got a decently strong motor at least.
                  I was just talking to the owner of BoostLogic this morning. He dyno'd almost identical to me with a 71mm turbo (my turbo is 72mm). He made ~570rwhp on boost. He had a lockup converter and with the converter locked up he made 730rwhp! I knew there is a lot of loss through a high stall converter, but that seems just crazy.
                  • D Offline
                    D Offline
                    dynotune
                    I don't doubt that dave- the converters soak up soooo much power- alot of good race powerglides only take 20-30 HP to turn (which is minute) and I find alot of drag race guys that put 900 on the engine dyno only turn 550-650 on the chassis dyno. Time for 5 speed dyno time again???
                    andy
                    DynoTune Speed & Performance
                    Mobile chassis dyno service
                    www.dynotuneusa.com
                    (605) 753-1101
                    • DanglerD Offline
                      DanglerD Offline
                      Dangler
                      DaveH wrote:
                      ...he made 730rwhp! I knew there is a lot of loss through a high stall converter, but that seems just crazy.
                      I was saying to Stephen and TJamz that your turbo should be making 700+ rwhp. I was trying to figure out if the timing was conservative, the boost real low, or I had my numbers backwards.
                      Makes more sense now. Can you lock your converter up????
                        That lockup stuff is like $3000... too expensive for my cheap azz.
                        Andy, don't forget to add me to the dyno top ten now! 😄 I may bolt in the 5-speed and head down.... we'll see.
                        • DanglerD Offline
                          DanglerD Offline
                          Dangler
                          You got a clutch that will hold it?? BTW, Chris in Bismark is buying a Carbon \ Carbon - borrow it quickly with my tranny and make a few pulls.
                          $3k for lockup is ridiculous.
                          Timeslips are better than dyno graphs 😉
                            I'm not sure what the clutch will hold... it's a 6-puck ceramic. Prob about 591rwhp is where it would die. 😛 I took the auto trans out tonite... step 1.:D
                            • 9 Offline
                              9 Offline
                              92TSIpos
                              I was always wondering why you run with auto instead of manual. (dave h)
                                Consistency!!!! Alot less chance of missing a shift and possibly destroying an engine. Those 2 would be my first guesses.
                                  Ive seen it before, not quite those drastic of #'s but pretty far out there. it's not that your loosing hp. It's that the higher the stall, the more slippage at higher rpm's.
                                  O.K., it's loosing hp no matter how you look at it.
                                  • 9 Offline
                                    9 Offline
                                    92TSIpos
                                    Thats what i was thinking, just wanted second opinion.
                                    • 2wheeler2 Offline
                                      2wheeler2 Offline
                                      2wheeler
                                      I gonna go with that he wouldn't be nearly as quick. The quickest 6 speed Supra is 9.6 something, and that is with over 1000HP. Also, it was difficult to get clutches to hold the power.
                                      '08 Suzuki Hayabusa
                                      '09 Yamaha Zuma 200cc
                                      '95 E-350 7.5L
                                        Ethan is mostly right, it's really tough to get a clutch that will launch a (relatively) high HP car at the track. You can drop $4k on a tilton carbon/carbon but I think I'll pass on that. Plus with the auto, you can use a transbrake and build all the boost you want off the line. And finally, with a big turbo there is lag after you shift a manual trans... with the auto you just hold it to the floor and move the shifter.... keeps full HP going the whole pass.
                                        • 9 Offline
                                          9 Offline
                                          92TSIpos
                                          Lets all switch to auto 😄
