  3. Events
  4. Dyno in fargo Jan 8 & 9
134 Posts 35 Posters 9.7k Views
  • DanglerD Offline
    DanglerD Offline
    Dangler
    DaveH wrote:
    ...he made 730rwhp! I knew there is a lot of loss through a high stall converter, but that seems just crazy.
    I was saying to Stephen and TJamz that your turbo should be making 700+ rwhp. I was trying to figure out if the timing was conservative, the boost real low, or I had my numbers backwards.
    Makes more sense now. Can you lock your converter up????
      That lockup stuff is like $3000... too expensive for my cheap azz.
      Andy, don't forget to add me to the dyno top ten now! 😄 I may bolt in the 5-speed and head down.... we'll see.
      • DanglerD Offline
        DanglerD Offline
        Dangler
        You got a clutch that will hold it?? BTW, Chris in Bismark is buying a Carbon \ Carbon - borrow it quickly with my tranny and make a few pulls.
        $3k for lockup is ridiculous.
        Timeslips are better than dyno graphs 😉
          I'm not sure what the clutch will hold... it's a 6-puck ceramic. Prob about 591rwhp is where it would die. 😛 I took the auto trans out tonite... step 1.:D
          • 9 Offline
            9 Offline
            92TSIpos
            I was always wondering why you run with auto instead of manual. (dave h)
              Consistency!!!! Alot less chance of missing a shift and possibly destroying an engine. Those 2 would be my first guesses.
                DaveH wrote:
                I was just talking to the owner of BoostLogic this morning. He dyno'd almost identical to me with a 71mm turbo (my turbo is 72mm). He made ~570rwhp on boost. He had a lockup converter and with the converter locked up he made 730rwhp! I knew there is a lot of loss through a high stall converter, but that seems just crazy.
                Ive seen it before, not quite those drastic of #'s but pretty far out there. it's not that your loosing hp. It's that the higher the stall, the more slippage at higher rpm's.
                O.K., it's loosing hp no matter how you look at it.
                • 9 Offline
                  9 Offline
                  92TSIpos
                  Thats what i was thinking, just wanted second opinion.
                  • 2wheeler2 Offline
                    2wheeler2 Offline
                    2wheeler
                    I gonna go with that he wouldn't be nearly as quick. The quickest 6 speed Supra is 9.6 something, and that is with over 1000HP. Also, it was difficult to get clutches to hold the power.
                    '08 Suzuki Hayabusa
                    '09 Yamaha Zuma 200cc
                    '95 E-350 7.5L
                      Ethan is mostly right, it's really tough to get a clutch that will launch a (relatively) high HP car at the track. You can drop $4k on a tilton carbon/carbon but I think I'll pass on that. Plus with the auto, you can use a transbrake and build all the boost you want off the line. And finally, with a big turbo there is lag after you shift a manual trans... with the auto you just hold it to the floor and move the shifter.... keeps full HP going the whole pass.
                      • 9 Offline
                        9 Offline
                        92TSIpos
                        Lets all switch to auto 😄
                          For drag racing, it's the way to go. For street driving, I'll take a manual transmission any day.
                          • 9 Offline
                            9 Offline
                            92TSIpos
                            I figured you were all auto. Was the car auto or manual stock?
                              It was originally a auto, then I converted it to 5-speed, then back to auto. My 3rd gen is 5-speed.
                                After reading this I think I need to do the lockup mod on my TC (mine requires $25 in parts to accomplish lockup.....glad I don't own a supra.....did I just say that??!?!?!)
                                  I think you did. Dave's problems solved...buy a wrx!
                                  • 9 Offline
                                    9 Offline
                                    92TSIpos
                                    Shit you must have had your car for a while. I didnt know you had two supras 😕
                                      Dave is your 3rd gen running?
                                        I had lockup on the built Toyota tranny that I had, but the clutches weren't strong enough and wouldn't hold at WOT. To get lockup on a Glide is serious coin.
                                        I messed up 2 pistons on the MKIII a couple years ago (accidental 30+ psi). I got parts, I just need to put it back together again. I'll have supra number 3 here in a couple weeks.
                                          what year supra are you getting now and is it turboed?
