  4. Question for people that store there cars
22 Posts 11 Posters 1.7k Views
  • 95accord9 Offline
    95accord9 Offline
    95accord
    this is my first winter that i have ever stored a car. im just checken to see what other people do when they store theres. its gonna sit in my garage, unheated but insulated. do i put enough gas in it and start it once a week, like i said im new to this storage this so if anyone could help me out with some feedback that would be great.
    05 Toyota Corolla- Wifys car
      Fill gas tank and add stabil.
      Drive car into garage
      Disconnect battery
      Cover car
      Wait until spring time and do the reverse
      • 95accord9 Offline
        95accord9 Offline
        95accord
        thats it....isnt it bad for the motor if there is no oil circulation?
          Not really, if you really want to be safe, put some oil in the cylinders before starting it. Unplug the dizzy and turn it over to get oil flowing before starting it. A stock honda motor won't have problems being stored for awhile....
            The motor is not running either. It is harder on the engine to start it every week or whatever.
            • ruthless351R Offline
              ruthless351
              It will be just fine. Cmk has the right idea.
              • 95accord9 Offline
                95accord9 Offline
                95accord
                is this what you do to your ride ruthless, i noticed you have yours covered, and stabil is the stuff in the red container right? i have some that i use in the snowblower and mower.Do you fill the tank completely full also?
                  I don't put a cover on it, and wouldn't unless it is high quality with good air flow, moisture can get trapped between the fabric and paint and other problems. I have never covered my cars, but i always use a clean garage. Yes stabil the red stuff, and fill the tank or moisture will be in the air inside it and rust your tank.
                  • SlowicaS Offline
                    SlowicaS Offline
                    Slowica
                    i do what CMK said minus covering. I also run some seafoam through it before i store it to get some moisture out of the lines and such.
                      dont forget to change your coolant if you use plain water....
                        thrash
                        in the past i've stored the car in a friends barn. stabil, disconnect battery, apply car cover are all things I do. In addition, i stuff dryer sheets all over the car (interior and underhood) as apparently Mice hate the smell and won't go near a car. Otherwise Mice and other critters will figure your car is a pretty good place to setup shop for the winter. Debugging a wiring harness fault due to rodent activity is awful.
                        • 95accord9 Offline
                          95accord9 Offline
                          95accord
                          well thanks guys for all your input, i think i can finally do it, is it save to leave the aftermarket wheels i have on or should i put the stocks back on? anyone else has any suggestions feel free to let me know
                            ruthless351
                            Yep! I fill the tank full and add the stabil stuff. You fill it full to keep the condensation down. I also change the tires for my shitty tires. I have the time to do this so it keeps the weather from cracking my summer tires. Thats just me though. 🙂
                              How are aftermarket wheels different than stock wheels as far as the car simply sitting on them?
                              • gsrEKG Offline
                                gsrEKG Offline
                                gsrEK
                                whew just did that lol
                                im just tryin to figure out wat to do with my e85 business in my car???? im scared my tank is gonna rust out
                                2009 Yamaha Zuma 125, gas HOG
                                2008 Honda Fit daily
                                A s2k
                                1991 Honda civic DX Mint SOLD
                                1988 Mitsubishi Mighty max
                                > BlackEJ8;233529 wrote:
                                • eveslowE Offline
                                  eveslowE Offline
                                  eveslow
                                  i plan on storing my car this winter and i was wondering if heated storage is worth it or if i should just store it in the cold?
                                  2003 Mitsubishi Evolution VIII W/ stage 2 slowboyracing short block. Eagle H-Beam Chrome Moly Rods, Ross Racing Forged 8.5:1 Pistons, Clevite 77 Rod Bearings, Clevite 77 Main Bearings, ARP Rod Bolts. everything else pretty much stock. near future GT35R turbo kit
                                  AKA cleanest Evo in town
                                  • no_slow_clapN Offline
                                    no_slow_clap
                                    park it on jack stands and have any sort of rodent repelant in/around the car.
                                    EVOLUTION VIII
                                      Flat spotting the tires? I don't know, just something I read.
                                        Convert back to pump gas like i already told you. Easy enough.
                                          That used to be a problem with bias ply tires, but with radials any flat spot that might occur will be gone by the time you are around the block. Remember, parking a car for winter is only 5 or 6 months, not years.
