  4. Question for people that store there cars
22 Posts 11 Posters 1.8k Views
    95accord;243536 wrote:
    thats it....isnt it bad for the motor if there is no oil circulation?
    Not really, if you really want to be safe, put some oil in the cylinders before starting it. Unplug the dizzy and turn it over to get oil flowing before starting it. A stock honda motor won't have problems being stored for awhile....
      The motor is not running either. It is harder on the engine to start it every week or whatever.
      • ruthless351R Offline
        ruthless351
        It will be just fine. Cmk has the right idea.
        • 95accord9 Offline
          95accord9 Offline
          95accord
          is this what you do to your ride ruthless, i noticed you have yours covered, and stabil is the stuff in the red container right? i have some that i use in the snowblower and mower.Do you fill the tank completely full also?
          05 Toyota Corolla- Wifys car
            I don't put a cover on it, and wouldn't unless it is high quality with good air flow, moisture can get trapped between the fabric and paint and other problems. I have never covered my cars, but i always use a clean garage. Yes stabil the red stuff, and fill the tank or moisture will be in the air inside it and rust your tank.
            • SlowicaS Offline
              SlowicaS Offline
              Slowica
              i do what CMK said minus covering. I also run some seafoam through it before i store it to get some moisture out of the lines and such.
                dont forget to change your coolant if you use plain water....
                  thrash
                  in the past i've stored the car in a friends barn. stabil, disconnect battery, apply car cover are all things I do. In addition, i stuff dryer sheets all over the car (interior and underhood) as apparently Mice hate the smell and won't go near a car. Otherwise Mice and other critters will figure your car is a pretty good place to setup shop for the winter. Debugging a wiring harness fault due to rodent activity is awful.
                  • 95accord9 Offline
                    95accord9 Offline
                    95accord
                    well thanks guys for all your input, i think i can finally do it, is it save to leave the aftermarket wheels i have on or should i put the stocks back on? anyone else has any suggestions feel free to let me know
                      ruthless351
                      Yep! I fill the tank full and add the stabil stuff. You fill it full to keep the condensation down. I also change the tires for my shitty tires. I have the time to do this so it keeps the weather from cracking my summer tires. Thats just me though. 🙂
                        How are aftermarket wheels different than stock wheels as far as the car simply sitting on them?
                        • gsrEKG Offline
                          gsrEKG Offline
                          gsrEK
                          whew just did that lol
                          im just tryin to figure out wat to do with my e85 business in my car???? im scared my tank is gonna rust out
                          2009 Yamaha Zuma 125, gas HOG
                          2008 Honda Fit daily
                          A s2k
                          1991 Honda civic DX Mint SOLD
                          1988 Mitsubishi Mighty max
                          > BlackEJ8;233529 wrote:
                          • eveslowE Offline
                            eveslowE Offline
                            eveslow
                            i plan on storing my car this winter and i was wondering if heated storage is worth it or if i should just store it in the cold?
                            2003 Mitsubishi Evolution VIII W/ stage 2 slowboyracing short block. Eagle H-Beam Chrome Moly Rods, Ross Racing Forged 8.5:1 Pistons, Clevite 77 Rod Bearings, Clevite 77 Main Bearings, ARP Rod Bolts. everything else pretty much stock. near future GT35R turbo kit
                            AKA cleanest Evo in town
                            • no_slow_clapN Offline
                              no_slow_clap
                              park it on jack stands and have any sort of rodent repelant in/around the car.
                              EVOLUTION VIII
                                Flat spotting the tires? I don't know, just something I read.
                                  Convert back to pump gas like i already told you. Easy enough.
                                    That used to be a problem with bias ply tires, but with radials any flat spot that might occur will be gone by the time you are around the block. Remember, parking a car for winter is only 5 or 6 months, not years.
                                    • gsrEKG Offline
                                      gsrEKG Offline
                                      gsrEK
                                      um cant get a basemap u not here......:icon_scratch:
                                      A s2k
                                        You should have thought of that earlier. Just put in a stock ECU and stock injectors with stock map sensor.
