Question for people that store there cars
in the past i've stored the car in a friends barn. stabil, disconnect battery, apply car cover are all things I do. In addition, i stuff dryer sheets all over the car (interior and underhood) as apparently Mice hate the smell and won't go near a car. Otherwise Mice and other critters will figure your car is a pretty good place to setup shop for the winter. Debugging a wiring harness fault due to rodent activity is awful.
95accord;243543 wrote:
is this what you do to your ride ruthless, i noticed you have yours covered, and stabil is the stuff in the red container right? i have some that i use in the snowblower and mower.Do you fill the tank completely full also?Yep! I fill the tank full and add the stabil stuff. You fill it full to keep the condensation down. I also change the tires for my shitty tires. I have the time to do this so it keeps the weather from cracking my summer tires. Thats just me though.
95accord;243672 wrote:
well thanks guys for all your input, i think i can finally do it, is it save to leave the aftermarket wheels i have on or should i put the stocks back on? anyone else has any suggestions feel free to let me knowHow are aftermarket wheels different than stock wheels as far as the car simply sitting on them?
park it on jack stands and have any sort of rodent repelant in/around the car.
gsrEK;243704 wrote:
whew just did that lolim just tryin to figure out wat to do with my e85 business in my car???? im scared my tank is gonna rust out
Convert back to pump gas like i already told you. Easy enough.
HandoEX;243723 wrote:
Flat spotting the tires? I don't know, just something I read.That used to be a problem with bias ply tires, but with radials any flat spot that might occur will be gone by the time you are around the block. Remember, parking a car for winter is only 5 or 6 months, not years.
gsrEK;243735 wrote:
um cant get a basemap u not here......:icon_scratch:You should have thought of that earlier. Just put in a stock ECU and stock injectors with stock map sensor.
