  4. AMS twin sequential setup....NUTS
25 Posts 12 Posters 3.4k Views
  • K
    K
    no_slow_clap;249920 wrote:
    the exhaust was never entering the small turbo, they couldnt get it to tune right so they just went with the 42.
    If you look at the small turbo, there is a turbo flange that comes off of the down pipe of the gt42 to feed the gt28. It does not suprise me that they could not tune it.
    • Gundar1G
      Gundar1G
      Gundar1
      Oh.
      EVO
      • no_slow_clapN
        no_slow_clapN
        no_slow_clap
        i see now, i didnt know they were using a valving system on it. it makes more sence. i can see the smaller turbo being a choke point for the bigger if fed other way.
        EVOLUTION VIII
        ryanherington;4648360 wrote:
        I think I'm gonna stop by Autozone and get a "worthy-amount" meter. My car might not put down enough worhty, and I don't wanna get in the way.
        • DrifterExtremeD
          DrifterExtremeD
          they should have set it up with a 3rd wastegate to feed the small turbo from the manifold and left the valves on the big turbo to open based on vacume or a set psi of boost. it would seem to allow some flow through them to get them up to speed.
          • MisterCMKM
            MisterCMKM
            I would be a man and put in a 4th wastegate. Anything less is for babydick wannabes.
            thrash;315544 wrote:
            Ford is back :)
            • zbrownZ
              zbrownZ
              looks like a overly complicated mix of a compound and seq. system
              those guys would be running high pressure ratios on a drag setup........ a straight compound system would have worked perfectly and been 1/3 as complicated
              compounds shine at high press. ratios.........seq. FTL all together
              • fdfreakF
                fdfreakF
                fdfreak
                ^they complicated things just a little. thats alright, you'll never know if something works if you dont ever try it.
                12.645@118mph 12.6psi
                • SlowicaS
                  SlowicaS
                  Slowica
                  hopefully they release vids of it on the strip.
                  • no_slow_clapN
                    no_slow_clapN
                    no_slow_clap
                    it never got finished
                    EVOLUTION VIII
                    • K
                      K
                      Sounds about right....
                      • bubbaB
                        bubbaB
                        the motor did win the top shop challenge... iirc it was like 1043hp or something... I still thought Bisimotos all motor engine was sweeter... 350+ hp on a F22 non-vtec and 100 octane..
                        • GrrG
                          GrrG
                          they would have been way better off using a large divided housing with a butterfly valve into the other side. so its only using half the housing at spoolup. works slicker than shit.
                          • BassplayerB
                            BassplayerB
                            Bassplayer
                            pic of the f22?
                            1995 GMC Sierra
                            • bubbaB
                              bubbaB
                              Bassplayer;250266 wrote:
                              pic of the f22?
                              super street...
                              has a sick itb setup and header too...
                              • RexwagonR
                                RexwagonR
                                Swt bld.
