  4. AMS twin sequential setup....NUTS
25 Posts 12 Posters 3.4k Views
  • K
    K
    More pics???????????
    Whats feeding the tiny turbo?
    • no_slow_clapN
      no_slow_clapN
      no_slow_clap
      NOTHING!! the small trubo feeds into the dump of the bigger turbo!
      EVOLUTION VIII
      ryanherington;4648360 wrote:
      I think I'm gonna stop by Autozone and get a "worthy-amount" meter. My car might not put down enough worhty, and I don't wanna get in the way.
      • BassplayerB
        BassplayerB
        Bassplayer
        Wow that's a fricking puzzle to look at. So how the fuck is the small turbo being powered? my head hurts it's too early haha
        1995 GMC Sierra
        • K
          K
          What I was meaning is where is the exhuast enting the turbo? I went and found the pics.
          Where did the second turbo go?
          • Gundar1G
            Gundar1G
            Gundar1
            Thats sweet, saw that in modified mag last month.
            EVO
            • no_slow_clapN
              no_slow_clapN
              no_slow_clap
              the exhaust was never entering the small turbo, they couldnt get it to tune right so they just went with the 42.
              EVOLUTION VIII
              • Gundar1G
                Gundar1G
                Gundar1
                thats the motor modified mag had ams build for the top shop challenge thing, they're two different setups.
                EVO
                • K
                  K
                  Not according to AMS.
                  http://forums.evolutionm.net/showthread.php?t=376412
                  • DrifterExtremeD
                    DrifterExtremeD
                    if you look you can see there is a huge valve on the downpipe of the big turbo, that shuts off the dp. then the smaller turbo is fed from the downpipe when the valve is shut and the big turbo isn't up to speed.
                    the second valve on the intake of the big turbo looks as if it blocks off the big turbo's inlet to allow the small turbo to spool the big turbo.
                    see simple... lol
                    • K
                      K
                      If you look at the small turbo, there is a turbo flange that comes off of the down pipe of the gt42 to feed the gt28. It does not suprise me that they could not tune it.
                      • Gundar1G
                        Gundar1G
                        Gundar1
                        Oh.
                        EVO
                        • no_slow_clapN
                          no_slow_clapN
                          no_slow_clap
                          i see now, i didnt know they were using a valving system on it. it makes more sence. i can see the smaller turbo being a choke point for the bigger if fed other way.
                          EVOLUTION VIII
                          • DrifterExtremeD
                            DrifterExtremeD
                            they should have set it up with a 3rd wastegate to feed the small turbo from the manifold and left the valves on the big turbo to open based on vacume or a set psi of boost. it would seem to allow some flow through them to get them up to speed.
                            • MisterCMKM
                              MisterCMKM
                              I would be a man and put in a 4th wastegate. Anything less is for babydick wannabes.
                              thrash;315544 wrote:
                              Ford is back :)
                              • zbrownZ
                                zbrownZ
                                looks like a overly complicated mix of a compound and seq. system
                                those guys would be running high pressure ratios on a drag setup........ a straight compound system would have worked perfectly and been 1/3 as complicated
                                compounds shine at high press. ratios.........seq. FTL all together
                                • fdfreakF
                                  fdfreakF
                                  fdfreak
                                  ^they complicated things just a little. thats alright, you'll never know if something works if you dont ever try it.
                                  12.645@118mph 12.6psi
                                  • SlowicaS
                                    SlowicaS
                                    Slowica
                                    hopefully they release vids of it on the strip.
                                    • no_slow_clapN
                                      no_slow_clapN
                                      no_slow_clap
                                      it never got finished
                                      EVOLUTION VIII
                                      • K
                                        K
                                        Sounds about right....
                                        • bubbaB
                                          bubbaB
                                          the motor did win the top shop challenge... iirc it was like 1043hp or something... I still thought Bisimotos all motor engine was sweeter... 350+ hp on a F22 non-vtec and 100 octane..
