  4. AMS twin sequential setup....NUTS
25 Posts 12 Posters 3.3k Views
  • no_slow_clapN Offline
    no_slow_clap
    NOTHING!! the small trubo feeds into the dump of the bigger turbo!
    EVOLUTION VIII
    • BassplayerB Offline
      BassplayerB Offline
      Bassplayer
      Wow that's a fricking puzzle to look at. So how the fuck is the small turbo being powered? my head hurts it's too early haha
      1995 GMC Sierra
        What I was meaning is where is the exhuast enting the turbo? I went and found the pics.
        Where did the second turbo go?
        • Gundar1G Offline
          Gundar1G Offline
          Gundar1
          Thats sweet, saw that in modified mag last month.
          EVO
            no_slow_clap
            the exhaust was never entering the small turbo, they couldnt get it to tune right so they just went with the 42.
            EVOLUTION VIII
            • Gundar1G Offline
              Gundar1G Offline
              Gundar1
              thats the motor modified mag had ams build for the top shop challenge thing, they're two different setups.
              EVO
                Not according to AMS.
                http://forums.evolutionm.net/showthread.php?t=376412
                  if you look you can see there is a huge valve on the downpipe of the big turbo, that shuts off the dp. then the smaller turbo is fed from the downpipe when the valve is shut and the big turbo isn't up to speed.
                  the second valve on the intake of the big turbo looks as if it blocks off the big turbo's inlet to allow the small turbo to spool the big turbo.
                  see simple... lol
                    If you look at the small turbo, there is a turbo flange that comes off of the down pipe of the gt42 to feed the gt28. It does not suprise me that they could not tune it.
                    • Gundar1G Offline
                      Gundar1G Offline
                      Gundar1
                      Oh.
                      EVO
                        no_slow_clap
                        i see now, i didnt know they were using a valving system on it. it makes more sence. i can see the smaller turbo being a choke point for the bigger if fed other way.
                        EVOLUTION VIII
                          they should have set it up with a 3rd wastegate to feed the small turbo from the manifold and left the valves on the big turbo to open based on vacume or a set psi of boost. it would seem to allow some flow through them to get them up to speed.
                            I would be a man and put in a 4th wastegate. Anything less is for babydick wannabes.
                              looks like a overly complicated mix of a compound and seq. system
                              those guys would be running high pressure ratios on a drag setup........ a straight compound system would have worked perfectly and been 1/3 as complicated
                              compounds shine at high press. ratios.........seq. FTL all together
                              • fdfreakF Offline
                                fdfreakF Offline
                                fdfreak
                                ^they complicated things just a little. thats alright, you'll never know if something works if you dont ever try it.
                                12.645@118mph 12.6psi
                                • SlowicaS Offline
                                  SlowicaS Offline
                                  Slowica
                                  hopefully they release vids of it on the strip.
                                    no_slow_clap
                                    it never got finished
                                    EVOLUTION VIII
                                      Sounds about right....
                                        the motor did win the top shop challenge... iirc it was like 1043hp or something... I still thought Bisimotos all motor engine was sweeter... 350+ hp on a F22 non-vtec and 100 octane..
                                          they would have been way better off using a large divided housing with a butterfly valve into the other side. so its only using half the housing at spoolup. works slicker than shit.
