  4. AMS twin sequential setup....NUTS
25 Posts 12 Posters 3.2k Views
    Gundar1;249921 wrote:
    thats the motor modified mag had ams build for the top shop challenge thing, they're two different setups.
    Not according to AMS.
    http://forums.evolutionm.net/showthread.php?t=376412
      if you look you can see there is a huge valve on the downpipe of the big turbo, that shuts off the dp. then the smaller turbo is fed from the downpipe when the valve is shut and the big turbo isn't up to speed.
      the second valve on the intake of the big turbo looks as if it blocks off the big turbo's inlet to allow the small turbo to spool the big turbo.
      see simple... lol
        no_slow_clap;249920 wrote:
        the exhaust was never entering the small turbo, they couldnt get it to tune right so they just went with the 42.
        If you look at the small turbo, there is a turbo flange that comes off of the down pipe of the gt42 to feed the gt28. It does not suprise me that they could not tune it.
        • Gundar1G Offline
          Gundar1G Offline
          Gundar1
          Oh.
          EVO
          • no_slow_clapN Offline
            no_slow_clap
            i see now, i didnt know they were using a valving system on it. it makes more sence. i can see the smaller turbo being a choke point for the bigger if fed other way.
            EVOLUTION VIII
              they should have set it up with a 3rd wastegate to feed the small turbo from the manifold and left the valves on the big turbo to open based on vacume or a set psi of boost. it would seem to allow some flow through them to get them up to speed.
                I would be a man and put in a 4th wastegate. Anything less is for babydick wannabes.
                  looks like a overly complicated mix of a compound and seq. system
                  those guys would be running high pressure ratios on a drag setup........ a straight compound system would have worked perfectly and been 1/3 as complicated
                  compounds shine at high press. ratios.........seq. FTL all together
                  • fdfreakF Offline
                    fdfreakF Offline
                    fdfreak
                    ^they complicated things just a little. thats alright, you'll never know if something works if you dont ever try it.
                    12.645@118mph 12.6psi
                    • SlowicaS Offline
                      SlowicaS Offline
                      Slowica
                      hopefully they release vids of it on the strip.
                        no_slow_clap
                        it never got finished
                        EVOLUTION VIII
                          Sounds about right....
                            the motor did win the top shop challenge... iirc it was like 1043hp or something... I still thought Bisimotos all motor engine was sweeter... 350+ hp on a F22 non-vtec and 100 octane..
                              they would have been way better off using a large divided housing with a butterfly valve into the other side. so its only using half the housing at spoolup. works slicker than shit.
                              • BassplayerB Offline
                                BassplayerB Offline
                                Bassplayer
                                pic of the f22?
                                1995 GMC Sierra
                                  Bassplayer;250266 wrote:
                                  pic of the f22?
                                  super street...
                                  has a sick itb setup and header too...
                                    Swt bld.
