  4. A little of dyno time
26 Posts 11 Posters 2.4k Views
    NIG NOG!
    looks good! Decent power. I'm doing ECU chipping if you ever need it 🙂
      good job, what turbine side is that on the 71r?
      Also this pack dyno's read a bit higher correct?
      sounds like all is going well over there.
        Torques a little low
          I believe the owner said it was the .82 A/R housing. Dyna pack is going to read a bit higher because there is no loss for the weight of whees and resistance of tires, but Im not entirely sure how much and how it compares to other dynos. All the results that Full-Race puts out are from a dynapack (Locash Racing's) as well as all of the results from Jeff Evans Tuning.
          And it is a Honda, what do you expect it to have for torque....
          • no_slow_clapN Offline
            no_slow_clap
            yup, dyna packs have no load bearing on the rollers. There are some dyno jets that you put load on, and MD's are somewhat adjustable as far as how much load is put on.
            Sounds like you are having fun, what were you tuning with? You should throw up a dynosheet, possibly some logs from the tune you did.
            EVOLUTION VIII
              Zac, Dynapacks are loaded. We did some steady state tuning and then you can adjust the ramp up rate, and there are no rollers on it since it is a hub dyno. Most dynojets are not loaded, and all mustang dynos are loaded.
              It was tuned on Hondata S300. I did post the dynosheet on top.
              • gsrEKG Offline
                gsrEKG Offline
                gsrEK
                Zac = dyno guru now..........
                nice work trevor! P.S. Cant wait to c ya agian
                2009 Yamaha Zuma 125, gas HOG
                2008 Honda Fit daily
                A s2k
                1991 Honda civic DX Mint SOLD
                1988 Mitsubishi Mighty max
                  no_slow_clap
                  Oh, I didnt see the sheet (govt filter). Dyna packs are goofy.
                  there is one dyno jet that allow for load bearing. i dont recall the model number, but it one that my car was on a while ago.
                  I know that MD's are loaded, i just said the amount of load is adjustable.
                  EVOLUTION VIII
                    I am perty sure from what i have read that with a dyna pack you loose just a set amount of hp regardless of the amount of hp being produced....... instead of loosing a % of the hp on like a dyno jet
                    but yeah a typical higher reading on the dyna pack..... IMO a better dyno
                      Yeah, i have been on a few different dynos, but haven't done any tuning on the dyno, and the dynapack was great for it. Steady state mapping is SO much easier and quicker than street tuning.
                      And I can't wait to see you either Travy 😉
                        no_slow_clap
                        You dont loose HP on a dyon that reads lower.
                        In all reality, numbers dont mean much...if anything at all.
                        I too like to see the comparisons from dyno to dyno. I like the MD's
                        EVOLUTION VIII
                          there aren't any inertial losses on lets say a dyno jet huh :icon_scratch:
                            :lol: @ comparing dyno numbers between different dynos
                            You don't race dynos...
                              no_slow_clap
                              Why would there be? they are both inertia type dyno's.
                              assuming thats what you mean.
                              EVOLUTION VIII
                                Zacs a dyno guru on top of the Evo guru
                                • SlowicaS Offline
                                  SlowicaS Offline
                                  Slowica
                                  bow down lol
                                    he is saying it takes power to spin the huge rollers, unlike the small hubs on the pack dynos.
                                    correct z brown?
                                    • gsrEKG Offline
                                      gsrEKG Offline
                                      gsrEK
                                      Touche my friend
                                      A s2k
                                        which zac?...... I know you mean me in both instances...lol
                                          no_slow_clap
                                          basically.
                                          correct z brown?
                                          Ok. I was thinking of it more comparing MD, to a Dynojet
                                          EVOLUTION VIII
