  4. Is this another common problem with DSMs?
38 Posts 16 Posters 1.2k Views
  • 9 Offline
    9 Offline
    92TSIpos
    i feel your pain man, I went to put my car in reverse and it wouldnt go in at all. Then it overheated because all my "coolant" froze inside the radiator and now its sitting at stop n go :mad:
    POS
      Ouch that sucks to hear man. Just hope for an early spring.
        POS
        maybe you should have put some "coolant" in it
          Fucking cheap ass, putting near straight water in @ below zero temps...LMFAO. BTW that isnt your fluidyne is it?
            that would suck if it was. i told him the other day to put some coolant in it
              I Know how that is , R is hard to get in to when its cold out. You have a Jdm Tranny so you may want to look at your linkages and adjust them properly.. Also a good Idea to switch over to some othr fluids..
              Kevin
              sls
                my dsm has kinda been having the same going into (R) problem every now and then...and when it is a problem just keep on semi-forcing it in (dont grind it) and slightly let off the clutch a little bit until it pops into gear...thats what i do anyway and it works for me...then again, i got a new gvr4 😄 .....but its worth a shot
                  gvr4 as in tranny....doh!
                  • JamesonTSI-AWDJ Offline
                    JamesonTSI-AWD
                    yeah the cold is tuff for reverse sometimes but i have had the problem without the extreme cold, just put it in fourth and let off the clutch just a very little bit, and then put it in reverse quick, works everytime man
                    as far as the syncromesh, i wouldnt go with penzoil, i dont know if the put perafin in there like they do with there oil, but if they do it is no good, it is like a wax that will coat the gears, and builds up. i have seen some bad stuff happen to motors with penzoil!
                    NO PENZOIL! haha
                    97 Talon TSI AWD
                    [COLOR=Black]Mods- Upper and Lower Intercooler Piping, Injen Intake, and 1st Gen BOV[/COLOR]
                      NO PENZOIL! haha
                      maybe i'm just confused... but synchromesh isn't made by penzoil.......... ?
                        penzoil makes their own synchromesh
                          JamesonTSI-AWD
                          Bad93ex wrote:
                          I think I am going to try some Pennzoil Syncromesh. I have read on dsmtuners that it works well and is about $5 cheaper per bottle than the GM stuff even though it is the same stuff.
                          i have no idea..... i was just thinkin they probably would put parafin in there
                          97 Talon TSI AWD
                            sorry bout that... didn't read that post!
                              I agree...penzoil does not make very good oil. It just makes a mess. I have heard the same thing(no proof though) of havoline their products.
                                JamesonTSI-AWD
                                cheaper is generally not better, there is probably just more shitty addatives to make it cheaper!
                                97 Talon TSI AWD
                                  or it doesnt say GM on it and its not sold be a dealer?
                                  • blackcougarB Offline
                                    blackcougar
                                    POS
                                    You mean all your water froze in your radiator...
                                    Kevin
                                    sls
                                      blackcougar
                                      NO PENZOIL! haha
                                      Gm and Pennzoil Syncromesh are the same!!! Pennziol makes it for GM and has the same part number.. But i wouldnt use it.... lol
                                      Kevin
                                      sls
