  4. Is this another common problem with DSMs?
38 Posts 16 Posters 1.2k Views
    92TSIpos wrote:
    i feel your pain man, I went to put my car in reverse and it wouldnt go in at all. Then it overheated because all my "coolant" froze inside the radiator and now its sitting at stop n go :mad:
    POS
    maybe you should have put some "coolant" in it
      Fucking cheap ass, putting near straight water in @ below zero temps...LMFAO. BTW that isnt your fluidyne is it?
        that would suck if it was. i told him the other day to put some coolant in it
          I Know how that is , R is hard to get in to when its cold out. You have a Jdm Tranny so you may want to look at your linkages and adjust them properly.. Also a good Idea to switch over to some othr fluids..
          Kevin
          sls
            my dsm has kinda been having the same going into (R) problem every now and then...and when it is a problem just keep on semi-forcing it in (dont grind it) and slightly let off the clutch a little bit until it pops into gear...thats what i do anyway and it works for me...then again, i got a new gvr4 😄 .....but its worth a shot
              gvr4 as in tranny....doh!
              • JamesonTSI-AWDJ Offline
                JamesonTSI-AWD
                yeah the cold is tuff for reverse sometimes but i have had the problem without the extreme cold, just put it in fourth and let off the clutch just a very little bit, and then put it in reverse quick, works everytime man
                as far as the syncromesh, i wouldnt go with penzoil, i dont know if the put perafin in there like they do with there oil, but if they do it is no good, it is like a wax that will coat the gears, and builds up. i have seen some bad stuff happen to motors with penzoil!
                NO PENZOIL! haha
                97 Talon TSI AWD
                [COLOR=Black]Mods- Upper and Lower Intercooler Piping, Injen Intake, and 1st Gen BOV[/COLOR]
                  NO PENZOIL! haha
                  maybe i'm just confused... but synchromesh isn't made by penzoil.......... ?
                    penzoil makes their own synchromesh
                      JamesonTSI-AWD
                      Bad93ex wrote:
                      I think I am going to try some Pennzoil Syncromesh. I have read on dsmtuners that it works well and is about $5 cheaper per bottle than the GM stuff even though it is the same stuff.
                      i have no idea..... i was just thinkin they probably would put parafin in there
                      97 Talon TSI AWD
                        sorry bout that... didn't read that post!
                          I agree...penzoil does not make very good oil. It just makes a mess. I have heard the same thing(no proof though) of havoline their products.
                            JamesonTSI-AWD
                            cheaper is generally not better, there is probably just more shitty addatives to make it cheaper!
                            97 Talon TSI AWD
                              or it doesnt say GM on it and its not sold be a dealer?
                              • blackcougarB Offline
                                blackcougar
                                POS
                                You mean all your water froze in your radiator...
                                Kevin
                                sls
                                  blackcougar
                                  NO PENZOIL! haha
                                  Gm and Pennzoil Syncromesh are the same!!! Pennziol makes it for GM and has the same part number.. But i wouldnt use it.... lol
                                  Kevin
                                  sls
