  4. Anybody knowledgable with painting a home wall with a roller?
22 Posts 11 Posters 957 Views
  • FG2F Offline
    FG2F Offline
    FG2
    I have applied 4 coats, and the last 2 coats were to try and get rid of the uneven look. You can only see this unevenness from an angle with sunlight. Looking at the wall straight on looks awesome and even. It is NOT the sheetrock showing through.
    I was told to paint with a "W" technique, but it would appear I should have just gone straight up and down on the last coat?!? I obviously need another coat, but I want it to be the last.
    I would appreciate advice from someone who knows about painting.
    Details:
    Used a nice quality roller
    Used high end paint from Peterson Paint
    Was well shaken and stirred
    Help 😞
    • Jason
      What were your drying times? I had trouble with this when painting my store, but I switched paint and then quickly applied the two coats of paint with a short drying period in between and that fixed it... if you let it dry too long between coats it ends up looking funny at angles...
      I think the thickness of the rollers makes a difference too, depending on the texture on your walls... you want a smoother less fluffy one if theres no texture?
      I'm not a paint expert by any means though lol...
      • FG2F Offline
        FG2F Offline
        FG2
        these are 'orange peel' textured walls, and I used a medium thick roller for 'semi smooth' walls. Dry times were about....1 hour, maybe 2 max.
        Super frustrating
          You should try doing 2 coats, with like a 15-20 minute drying time inbetween instead of waiting the hour or two...
          Maybe somebody else can chime in...
            Trafik Jamz
            I'd have to agree with Jim on this. 2 coats w/ a less dry time (and maybe try and not do the "W" pattern of the 2nd coat following the same line as the "W" of the 1st coat...hard to do, I know)
            Also, the paint might cure and get rid of the blotches over a few days...if you have time/patience you might just want to wait it out.
            701.541.3484
            • ColinC Offline
              ColinC Offline
              Colin
              i have painted many a wall, and I would say that your results look a lot like what happens when a glossy-er paint is applied over less glossy base with some uneven rolling. If i were you, I would wait a day to see if it cures like chuck said, if not then go over the whole things in a V pattern with more paint than usual on your roller to apply a single "heavy" coat. just under the "smearing" amount of paint.
              PS: sometimes its actually minor dips etc in your sheet rock that cause odd light reflections with semi-gloss paints. a flat paint might solve this.
              • ColinC Offline
                ColinC Offline
                Colin
                If you want help i'm around this weekend.
                • FG2F Offline
                  FG2F Offline
                  FG2
                  I tried this on the basement the day after fighting with the upstairs. Similar result.
                  I thought the same thing (as far as curing), but that was painted last weekend. As for the "W", I did change area's for the "W" with different coats, but the last coat always showed up like in the picture.
                  This paint is an eggshell, and is fairly flat...I have waited since last weekend hoping for a 'cure' and no help. I may try the heavy 'V' pattern, but I first want to see if someone posts that is very experienced (ie - did/does it for a living), and can tell me for certain what I did wrong.
                  Also, throughout the coats, the splotchy areas changed, eliminating the waves to a wall (Again, something I tried to tell myself was happening haha)
                  Thank you very much for the information and offer to help. The house won't be officially done being built until the 19th of June (closing day). So it will be a few weeks yet before I can even get in there to fix it (They allow you to go in before the trim/cabinets/flooring is installed to do some accent painting....but only for one weekend...which was last weekend). If I don't find someone that can tell me "Do this, and stop doing this, and that will fix your issue", I may just hire a painter. I loath the look as of right now.....quick way to ruin a brand new home 'feel'. 😞
                    I've just painted a few times in my own house, so i'm no expert... but what i've found is that if you are using a gloss or semi-gloss paint, you will need to keep more paint in the roller compared to using a flat paint. hard to tell from the pics, but the paint looks like a semi-gloss. try keeping the roller more saturated with paint and use less pressure. Your mileage may vary.
                    • RE-EnemaR Offline
                      RE-EnemaR Offline
                      RE-Enema
                      Did you use a primer? Did you stir/shake the paint really well? There is a lot of pigment in the dark colors and if it is not fully mixed it could be a problem. If you did, it looks like the splotchy areas are where your roller ran dry. Professional painters usually have their rollers soaked with paint like Colin said. Rolling in a vertical W or V pattern up and down is the way the professionals do it. Don't let the roller run dry. Keep it saturated with paint. I have seen some bad paint before, but that rarely happens.
                      The other problem is the fact that there is natural light washing down the wall. This is always a problem on projects and wall/drywall finishes. It shows all mistakes and imperfections, compounded by a dark color.
                      I do think that if you have done everything correctly (ie. primer, well mixed, right roller) that a heavy continuous coat should do the trick. I am not a professional painter, but I have worked on many construction projects with professionals and had to deal with problems like yours. My painting experience is more than 10 houses. If you want to talk to a professional, I can give you some contacts.
                        He's got some layers of paint down now though, I would think he would be able to as you said, apply a couple new coats of paint, making sure that the roller stays wet, and a small drying time. I think the trick is to use more paint then you think you need on the brush / roller and the technique is to apply it to the point just before getting paint runs...
                        • RE-EnemaR Offline
                          RE-EnemaR Offline
                          RE-Enema
                          I agree Jim, but there is some missing info to rule out other problems. I am assuming that everthing prior to applying the paint was done correctly, but I still have to ask the question. You would be amazed at the things I have seen "professionals" forget or not do. I am not saying that he did this, but without all the information, I can only make a best guess.
                            How many coats of primer did you use? Looks to me like the sheetrock just soaked up more paint in some spots than others..
                            then again, it could be the way they put the texture on the wall..
                            • FG2F Offline
                              FG2F Offline
                              FG2
                              The home builder primes and paints the whole house one color, then they allow you to go in and paint walls accent colors/whatever before the flooring/trim/cabinets go in (which I did last weekend, and won't have access to it now until closing on June 19th). So I painted over their primer and 'standard' color, and all the other walls that I didn't paint over look great, so I'd assume it was primered, and correctly.
                              I think my error is in the fact that when I used the roller, I would roll roll roll until the roller was left with zero paint. I would paint a ~4' x 4' area until the roller ran out, then go over everything after roller was dry to smooth it out...I am assuming that is wrong. I should go until the roller is starting to thin out, then apply more paint to the roller and keep doing that until I have the wall covered, then go over the whole wall to smooth out?
                                Don't run the roller dry, keep it fairly wet all the time. I've never gone over the whole wall afterward.
                                • FG2F Offline
                                  FG2F Offline
                                  FG2
                                  Thanks for the help guys. I just called Peterson Paint as well, and they said the same thing. Just do vertical swipes of WET roller (avoiding any lines), then rewet roller and move over a bit (overlap 2-3") and do it again. He also said don't 'go back over the wall'. I will apply a liberal coat and see where it leads me, and if I still struggle, I will bite the bullet and hire someone.
                                  Thanks to all for the helpful information. I think this is the first thread for help I have seen that didn't turn into a 5 page disaster 🙂
                                  Take Care!
                                  Jason
                                  • RaiderR Offline
                                    RaiderR Offline
                                    Raider
                                    from all the painting I have done in my houses I always keep the roller wet and only go up and down....the "W" never worked for me...and never go over a area again after you have already painted it unless u need to remove a line and if so use very little pressure on the roller
                                    if you are cutting in the corners or another wall you want to cut with a heavy enough coat and then roll into the cut while still wet...its hard to do if only one person is painting
                                    POWERD BY
                                    • RE-EnemaR Offline
                                      RE-EnemaR Offline
                                      RE-Enema
                                      Some of the painters will throw their roller cover in the bucket of paint to let it soak. When they are done painting they will put the cover back into the paint and leave it in there until they need it again. Usually they are using 5gallon buckets. It might be hard to do with a 1gallon bucket.
                                        Waiting for 'Orange Box' Guru
                                        • FG2F Offline
                                          FG2F Offline
                                          FG2
                                          I would have done the up and down method from the get go, but I was told NOT too....Then I ask around from here to Peterson Paint, and the info I got, was bad. W didn't work for me either (obviously). Thanks for your help. I did figure out how to remove the brush strokes with the roller on my own (WOOT). Thanks for the time and help!
                                          So they obviously get it soaked to the core with paint. I will try this method in the tray (let it sit for a few minutes one way, then rotate, then apply). Thanks as well!
