  4. Twin scroll turbo on non-twin scroll manifold
12 Posts 9 Posters 1.1k Views
  • thurmanmermanT
    thurmanmermanT
    thurmanmerman
    Any pros or cons to running it this way? Its a fairly small turbo thats going to be on a stock dseries.
    Parker;299126 wrote:
    blah blah blah blah blah blah blah blah blah blah blah blah German cars are the best thing since sliced bread.
    • K
      K
      Just do it.
      • A
        A
        aliengotpsi
        maybe port the turbo ?
        Kevin Smith
        Straightlinedetailing.com
        • DelSlowD
          DelSlowD
          Just do it, its only going to spool a littler later and not make as much power. As that 'bar' is in the way just acting as resistance.
          • zbrownZ
            zbrownZ
            i agree
            • thurmanmermanT
              thurmanmermanT
              thurmanmerman
              KA-T_240;277743 wrote:
              Just do it.
              I am.
              How well do cast turbine housing take to porting? I don't feel like ruining a perfectly good housing cause its divided.
              Thats what I was thinking but wouldn't the exhaust gases pretty much split evenly between the scrolls even tho the manifold isn't a twin scroll?
              zbrown;277780 wrote:
              i agree See my reply to aliengotpsi. lol
              • SPANISH-RICES
                SPANISH-RICES
                wouldnt it technically spool up a little sooner being as the housing is technically smaller than a single scroll? just wouldnt flow as much?
                • DrifterExtremeD
                  DrifterExtremeD
                  depends on the turbine housing, and the motor,manifold, dp, etc.
                  but the divided turbo's can get away with running larger a/r turbine housings, sense the velocity is kept higher due to the divided manifold,and the split pulse helps spool alot.
                  will putting a divided turbo on a non- divided work YES, should you do it. um no.
                  want a cheap as shit divided manifold. do this.
                  take a factory z6 header cut the flange off the bottom section and weld runners to a turbo flange up above the header. there you go a divided top mount for dirt cheap.
                  • SPANISH-RICES
                    SPANISH-RICES
                    yumm, sinktrap
                    • inspector01I
                      inspector01I
                      I don't think it really matters what you do with it, because if it is like any of your other projects, it will never actually get finished.......
                      • DrifterExtremeD
                        DrifterExtremeD
                        ^^ oh snap
                        • BryceB
                          BryceB
                          Oh zing it cuts so deep.
