  4. Twin scroll turbo on non-twin scroll manifold
12 Posts 9 Posters 1.1k Views
    aliengotpsi
    maybe port the turbo ?
    Kevin Smith
    Straightlinedetailing.com
      Just do it, its only going to spool a littler later and not make as much power. As that 'bar' is in the way just acting as resistance.
        i agree
        • thurmanmermanT Offline
          thurmanmerman
          KA-T_240;277743 wrote:
          Just do it.
          I am.
          How well do cast turbine housing take to porting? I don't feel like ruining a perfectly good housing cause its divided.
          Thats what I was thinking but wouldn't the exhaust gases pretty much split evenly between the scrolls even tho the manifold isn't a twin scroll?
          zbrown;277780 wrote:
          i agree See my reply to aliengotpsi. lol
          > Parker;299126 wrote:
            wouldnt it technically spool up a little sooner being as the housing is technically smaller than a single scroll? just wouldnt flow as much?
              depends on the turbine housing, and the motor,manifold, dp, etc.
              but the divided turbo's can get away with running larger a/r turbine housings, sense the velocity is kept higher due to the divided manifold,and the split pulse helps spool alot.
              will putting a divided turbo on a non- divided work YES, should you do it. um no.
              want a cheap as shit divided manifold. do this.
              take a factory z6 header cut the flange off the bottom section and weld runners to a turbo flange up above the header. there you go a divided top mount for dirt cheap.
                yumm, sinktrap
                  I don't think it really matters what you do with it, because if it is like any of your other projects, it will never actually get finished.......
                    ^^ oh snap
                      Oh zing it cuts so deep.
