  4. My supra had a bad time last night.
26 Posts 10 Posters 1.6k Views
  • funky_monkey58F Offline
    funky_monkey58
    Last night I decided I would take my supra from St.Cloud up to swanville at night and do some street tuning on my way to my roommates parents place.....
    Well the bad luck began, my hood flew open on hwy 10 going about 70mph and fold backwards cracking my windshield and denting my roof, alright that sucked ass. So I ziptied it back shut and did not have any more problems with it.
    So just before elmsdale I hear a weird noise coming from me engine so I pull over in elmsdale and get out of the car to hear the engine closer... sure as shit it is knocking like a mad black woman wanting her child support.
    So I had a really bad time last night and will post pictures in the morning.
    The good news is I will rebuild this next week and be good to go. Since my roommate picked me up with a trailer (thank god and at 3am even what a nice guy). But where the car sits now in swanville there is a 4 post lift and plenty of tools for auto body working to fix my roof and pull my engine and replace it right here.
      were u tuning it? went too lean?
        funky_monkey58
        did not see an AFR above 15 during the entire process and that was for a second other wise was around 11-14 the entire time.
        • D S ohMD Offline
          D S ohMD Offline
          D S ohM
          Shitty!!!!!!
          I wanna go fast!
          • 91nbtsi9 Offline
            91nbtsi9 Offline
            Uhm, what fuel were you running? Timing? Sucks man. Good luck with rebuild.
              well, shit happens. Get it fixed! What did i tell you about that hood, dumbass
                Don't feel bad.... you surely are not the only one that has done this lately......:mad:
                I highly doubt it had anything to do with tunning.................. either a oiling or bearing setup issue....... that is i am assuming the noise you are hearing is a spun bearing
                  funky_monkey58
                  D S ohM;278804 wrote:
                  Shitty!!!!!!
                  Yarp.
                  A mix between 92 octane and 110.
                  Yeah oops. The hood was my stupidity for sure.
                  I will know for sure in the next few days when I tear it apart for replacement of a few key parts.
                    AFR leaner than 12:1 or so will certainly damage your motor, ESPECIALLY if you're not on race gas. What do most people tune their turbo motors to on race gas, about 12.5:1 at most?
                      funky_monkey58
                      I think your information is off just a bit. I generally shoot for a 13.5 afr. For a good tune.
                      • Bp-08B Offline
                        Bp-08B Offline
                        Bp-08
                        shouldnt it be 12:1 at WOT.
                        • beachbum_jonB Offline
                          beachbum_jon
                          you didnt do what i think you did...did you?
                          -John Adams, 1735-1826-
                            That's why you blew your car up then. 13.5:1 on a turbo motor is gonna meltdown. That might work on an N/A motor however.
                            • 91nbtsi9 Offline
                              91nbtsi9 Offline
                              Good luck with 13.5:) You can damage bearings due to knock. Let's see some pics when you get it apart!
                                funky_monkey58
                                I really do not see how I could have damaged anything with my tune. Considering I did not go into positive boost territory beyond 8psi max as that is what my wastegate is set to. And I was on the break in cycle so I really did not want boost affecting the piston ring seals.
                                  Well what was your a/f ratio and how much was it knocking? Even a little boost, running too lean and knocking will destroy bearings.
                                    funky_monkey58
                                    http://www.truaxmotorsports.com/supra/SupraKnock.AVI
                                    I don't think it was cause by me running lean or detonation. But we will see once I pull it apart if a piston is fucked I will eat my words.
                                    • fdfreakF Offline
                                      fdfreakF Offline
                                      fdfreak
                                      yep, it happened to me a year ago. scared the living sh*t out of me. hood was trashed and my roof was too. Nothing happened to my windshield though.
                                      12.645@118mph 12.6psi
                                        funky_monkey58
                                        Heres some more pics.
                                          funky_monkey58
                                          Carnage pictures this is what I found in rod #3
                                          If I would have had fair warning the guy I got the block from was incompetent in putting together an engine I would have had the crank cut and smoothed out.
                                          When I first popped the rod cap off it looked like there was no bearing at all and that thin pieces were what I managed to scrape off with a screwdriver.
