  4. My supra had a bad time last night.
26 Posts 10 Posters 1.8k Views
    AFR leaner than 12:1 or so will certainly damage your motor, ESPECIALLY if you're not on race gas. What do most people tune their turbo motors to on race gas, about 12.5:1 at most?
    • funky_monkey58F Offline
      funky_monkey58
      I think your information is off just a bit. I generally shoot for a 13.5 afr. For a good tune.
      • Bp-08B Offline
        Bp-08B Offline
        Bp-08
        shouldnt it be 12:1 at WOT.
        • beachbum_jonB Offline
          beachbum_jon
          zbrown;278811 wrote:
          Don't feel bad.... you surely are not the only one that has done this lately......:mad:
          I highly doubt it had anything to do with tunning.................. either a oiling or bearing setup issue....... that is i am assuming the noise you are hearing is a spun bearing
          you didnt do what i think you did...did you?
          -John Adams, 1735-1826-
            That's why you blew your car up then. 13.5:1 on a turbo motor is gonna meltdown. That might work on an N/A motor however.
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              Good luck with 13.5:) You can damage bearings due to knock. Let's see some pics when you get it apart!
                funky_monkey58
                I really do not see how I could have damaged anything with my tune. Considering I did not go into positive boost territory beyond 8psi max as that is what my wastegate is set to. And I was on the break in cycle so I really did not want boost affecting the piston ring seals.
                  Well what was your a/f ratio and how much was it knocking? Even a little boost, running too lean and knocking will destroy bearings.
                    funky_monkey58
                    http://www.truaxmotorsports.com/supra/SupraKnock.AVI
                    I don't think it was cause by me running lean or detonation. But we will see once I pull it apart if a piston is fucked I will eat my words.
                    • fdfreakF Offline
                      fdfreakF Offline
                      fdfreak
                      yep, it happened to me a year ago. scared the living sh*t out of me. hood was trashed and my roof was too. Nothing happened to my windshield though.
                      12.645@118mph 12.6psi
                        funky_monkey58
                        Heres some more pics.
                          funky_monkey58
                          Carnage pictures this is what I found in rod #3
                          If I would have had fair warning the guy I got the block from was incompetent in putting together an engine I would have had the crank cut and smoothed out.
                          When I first popped the rod cap off it looked like there was no bearing at all and that thin pieces were what I managed to scrape off with a screwdriver.
                            lol'd at that. when you buy a motor ive found its best to just use the parts and re-assemble everything yourself
                              this... lol
                                funky_monkey58
                                I should listen to you more often.:icon_salut:
                                On another note I got the block completely stripped down and it looks like I might be able to do a hone job and replace the rotating assembly.
                                Oh and I threw the crankshaft like it was a shot put right out the door of the shop..... Where it still lies and I will cut it in half and use it as an anchor for my canoe.
                                • 91nbtsi9 Offline
                                  91nbtsi9 Offline
                                  zbrown;279866 wrote:
                                  this... lol
                                  Ahh, well from the first post all we knew was that he went out and was doing some tuning. No knowledge of a fresh engine!
                                  Good luck with the rebuild!
                                    funky_monkey58
                                    Well the Block pistons rods and crank are all at the machine shop now.
                                    I am really looking forward to this being done.
                                      GL to you in the future. hopefully it all turns out for ya
