  4. My supra had a bad time last night.
26 Posts 10 Posters 1.8k Views
  • funky_monkey58F Offline
    funky_monkey58
    D S ohM;278804 wrote:
    Shitty!!!!!!
    Yarp.
    91nbtsi;278805 wrote:
    Uhm, what fuel were you running? Timing? Sucks man. Good luck with rebuild.
    A mix between 92 octane and 110.
    Grr;278810 wrote:
    well, shit happens. Get it fixed! What did i tell you about that hood, dumbass
    Yeah oops. The hood was my stupidity for sure.
    zbrown;278811 wrote:
    Don't feel bad.... you surely are not the only one that has done this lately......:mad:
    I highly doubt it had anything to do with tunning.................. either a oiling or bearing setup issue....... that is i am assuming the noise you are hearing is a spun bearing
    I will know for sure in the next few days when I tear it apart for replacement of a few key parts.
      AFR leaner than 12:1 or so will certainly damage your motor, ESPECIALLY if you're not on race gas. What do most people tune their turbo motors to on race gas, about 12.5:1 at most?
        funky_monkey58
        I think your information is off just a bit. I generally shoot for a 13.5 afr. For a good tune.
        • Bp-08B Offline
          Bp-08B Offline
          Bp-08
          shouldnt it be 12:1 at WOT.
          • beachbum_jonB Offline
            beachbum_jon
            you didnt do what i think you did...did you?
            -John Adams, 1735-1826-
              That's why you blew your car up then. 13.5:1 on a turbo motor is gonna meltdown. That might work on an N/A motor however.
              • 91nbtsi9 Offline
                91nbtsi9 Offline
                Good luck with 13.5:) You can damage bearings due to knock. Let's see some pics when you get it apart!
                  funky_monkey58
                  I really do not see how I could have damaged anything with my tune. Considering I did not go into positive boost territory beyond 8psi max as that is what my wastegate is set to. And I was on the break in cycle so I really did not want boost affecting the piston ring seals.
                    Well what was your a/f ratio and how much was it knocking? Even a little boost, running too lean and knocking will destroy bearings.
                      funky_monkey58
                      http://www.truaxmotorsports.com/supra/SupraKnock.AVI
                      I don't think it was cause by me running lean or detonation. But we will see once I pull it apart if a piston is fucked I will eat my words.
                      • fdfreakF Offline
                        fdfreakF Offline
                        fdfreak
                        yep, it happened to me a year ago. scared the living sh*t out of me. hood was trashed and my roof was too. Nothing happened to my windshield though.
                        12.645@118mph 12.6psi
                          funky_monkey58
                          Heres some more pics.
                            funky_monkey58
                            Carnage pictures this is what I found in rod #3
                            If I would have had fair warning the guy I got the block from was incompetent in putting together an engine I would have had the crank cut and smoothed out.
                            When I first popped the rod cap off it looked like there was no bearing at all and that thin pieces were what I managed to scrape off with a screwdriver.
                              lol'd at that. when you buy a motor ive found its best to just use the parts and re-assemble everything yourself
                                this... lol
                                  funky_monkey58
                                  I should listen to you more often.:icon_salut:
                                  On another note I got the block completely stripped down and it looks like I might be able to do a hone job and replace the rotating assembly.
                                  Oh and I threw the crankshaft like it was a shot put right out the door of the shop..... Where it still lies and I will cut it in half and use it as an anchor for my canoe.
                                  • 91nbtsi9 Offline
                                    91nbtsi9 Offline
                                    zbrown;279866 wrote:
                                    this... lol
                                    Ahh, well from the first post all we knew was that he went out and was doing some tuning. No knowledge of a fresh engine!
                                    Good luck with the rebuild!
                                      funky_monkey58
                                      Well the Block pistons rods and crank are all at the machine shop now.
                                      I am really looking forward to this being done.
                                        GL to you in the future. hopefully it all turns out for ya
