  4. My supra had a bad time last night.
26 Posts 10 Posters 1.8k Views
  • 91nbtsi9 Offline
    91nbtsi9 Offline
    Good luck with 13.5:) You can damage bearings due to knock. Let's see some pics when you get it apart!
    • funky_monkey58F Offline
      funky_monkey58
      I really do not see how I could have damaged anything with my tune. Considering I did not go into positive boost territory beyond 8psi max as that is what my wastegate is set to. And I was on the break in cycle so I really did not want boost affecting the piston ring seals.
        Well what was your a/f ratio and how much was it knocking? Even a little boost, running too lean and knocking will destroy bearings.
          funky_monkey58
          http://www.truaxmotorsports.com/supra/SupraKnock.AVI
          I don't think it was cause by me running lean or detonation. But we will see once I pull it apart if a piston is fucked I will eat my words.
          • fdfreakF Offline
            fdfreakF Offline
            fdfreak
            zbrown;278811 wrote:
            Don't feel bad.... you surely are not the only one that has done this lately......:mad:
            yep, it happened to me a year ago. scared the living sh*t out of me. hood was trashed and my roof was too. Nothing happened to my windshield though.
            12.645@118mph 12.6psi
              funky_monkey58
              Heres some more pics.
                funky_monkey58
                Carnage pictures this is what I found in rod #3
                If I would have had fair warning the guy I got the block from was incompetent in putting together an engine I would have had the crank cut and smoothed out.
                When I first popped the rod cap off it looked like there was no bearing at all and that thin pieces were what I managed to scrape off with a screwdriver.
                  lol'd at that. when you buy a motor ive found its best to just use the parts and re-assemble everything yourself
                    I highly doubt it had anything to do with tunning.................. either a oiling or bearing setup issue.......
                    this... lol
                      funky_monkey58
                      I should listen to you more often.:icon_salut:
                      On another note I got the block completely stripped down and it looks like I might be able to do a hone job and replace the rotating assembly.
                      Oh and I threw the crankshaft like it was a shot put right out the door of the shop..... Where it still lies and I will cut it in half and use it as an anchor for my canoe.
                      • 91nbtsi9 Offline
                        91nbtsi9 Offline
                        zbrown;279866 wrote:
                        this... lol
                        Ahh, well from the first post all we knew was that he went out and was doing some tuning. No knowledge of a fresh engine!
                        Good luck with the rebuild!
                          funky_monkey58
                          Well the Block pistons rods and crank are all at the machine shop now.
                          I am really looking forward to this being done.
                            GL to you in the future. hopefully it all turns out for ya
