  4. My supra had a bad time last night.
26 Posts 10 Posters 1.8k Views
  • funky_monkey58F Offline
    funky_monkey58
    I really do not see how I could have damaged anything with my tune. Considering I did not go into positive boost territory beyond 8psi max as that is what my wastegate is set to. And I was on the break in cycle so I really did not want boost affecting the piston ring seals.
      Well what was your a/f ratio and how much was it knocking? Even a little boost, running too lean and knocking will destroy bearings.
        funky_monkey58
        http://www.truaxmotorsports.com/supra/SupraKnock.AVI
        I don't think it was cause by me running lean or detonation. But we will see once I pull it apart if a piston is fucked I will eat my words.
        • fdfreakF Offline
          fdfreakF Offline
          fdfreak
          zbrown;278811 wrote:
          Don't feel bad.... you surely are not the only one that has done this lately......:mad:
          yep, it happened to me a year ago. scared the living sh*t out of me. hood was trashed and my roof was too. Nothing happened to my windshield though.
          12.645@118mph 12.6psi
            funky_monkey58
            Heres some more pics.
              funky_monkey58
              Carnage pictures this is what I found in rod #3
              If I would have had fair warning the guy I got the block from was incompetent in putting together an engine I would have had the crank cut and smoothed out.
              When I first popped the rod cap off it looked like there was no bearing at all and that thin pieces were what I managed to scrape off with a screwdriver.
                lol'd at that. when you buy a motor ive found its best to just use the parts and re-assemble everything yourself
                  I highly doubt it had anything to do with tunning.................. either a oiling or bearing setup issue.......
                  this... lol
                    funky_monkey58
                    I should listen to you more often.:icon_salut:
                    On another note I got the block completely stripped down and it looks like I might be able to do a hone job and replace the rotating assembly.
                    Oh and I threw the crankshaft like it was a shot put right out the door of the shop..... Where it still lies and I will cut it in half and use it as an anchor for my canoe.
                    • 91nbtsi9 Offline
                      91nbtsi9 Offline
                      zbrown;279866 wrote:
                      this... lol
                      Ahh, well from the first post all we knew was that he went out and was doing some tuning. No knowledge of a fresh engine!
                      Good luck with the rebuild!
                        funky_monkey58
                        Well the Block pistons rods and crank are all at the machine shop now.
                        I am really looking forward to this being done.
                          GL to you in the future. hopefully it all turns out for ya
