  4. My supra had a bad time last night.
26 Posts 10 Posters 1.8k Views
  • funky_monkey58F Offline
    funky_monkey58
    did not see an AFR above 15 during the entire process and that was for a second other wise was around 11-14 the entire time.
    • D S ohMD Offline
      D S ohMD Offline
      D S ohM
      Shitty!!!!!!
      I wanna go fast!
      • 91nbtsi9 Offline
        91nbtsi9 Offline
        Uhm, what fuel were you running? Timing? Sucks man. Good luck with rebuild.
          well, shit happens. Get it fixed! What did i tell you about that hood, dumbass
            funky_monkey58;278797 wrote:
            Well the bad luck began, my hood flew open on hwy 10 going about 70mph and fold backwards cracking my windshield and denting my roof, alright that sucked ass. So I ziptied it back shut and did not have any more problems with it.
            Don't feel bad.... you surely are not the only one that has done this lately......:mad:
            I highly doubt it had anything to do with tunning.................. either a oiling or bearing setup issue....... that is i am assuming the noise you are hearing is a spun bearing
              funky_monkey58
              D S ohM;278804 wrote:
              Shitty!!!!!!
              Yarp.
              A mix between 92 octane and 110.
              Yeah oops. The hood was my stupidity for sure.
              I will know for sure in the next few days when I tear it apart for replacement of a few key parts.
                AFR leaner than 12:1 or so will certainly damage your motor, ESPECIALLY if you're not on race gas. What do most people tune their turbo motors to on race gas, about 12.5:1 at most?
                  funky_monkey58
                  I think your information is off just a bit. I generally shoot for a 13.5 afr. For a good tune.
                  • Bp-08B Offline
                    Bp-08B Offline
                    Bp-08
                    shouldnt it be 12:1 at WOT.
                    • beachbum_jonB Offline
                      beachbum_jon
                      you didnt do what i think you did...did you?
                      -John Adams, 1735-1826-
                        That's why you blew your car up then. 13.5:1 on a turbo motor is gonna meltdown. That might work on an N/A motor however.
                        • 91nbtsi9 Offline
                          91nbtsi9 Offline
                          Good luck with 13.5:) You can damage bearings due to knock. Let's see some pics when you get it apart!
                            funky_monkey58
                            I really do not see how I could have damaged anything with my tune. Considering I did not go into positive boost territory beyond 8psi max as that is what my wastegate is set to. And I was on the break in cycle so I really did not want boost affecting the piston ring seals.
                              Well what was your a/f ratio and how much was it knocking? Even a little boost, running too lean and knocking will destroy bearings.
                                funky_monkey58
                                http://www.truaxmotorsports.com/supra/SupraKnock.AVI
                                I don't think it was cause by me running lean or detonation. But we will see once I pull it apart if a piston is fucked I will eat my words.
                                • fdfreakF Offline
                                  fdfreakF Offline
                                  fdfreak
                                  yep, it happened to me a year ago. scared the living sh*t out of me. hood was trashed and my roof was too. Nothing happened to my windshield though.
                                  12.645@118mph 12.6psi
                                    funky_monkey58
                                    Heres some more pics.
                                      funky_monkey58
                                      Carnage pictures this is what I found in rod #3
                                      If I would have had fair warning the guy I got the block from was incompetent in putting together an engine I would have had the crank cut and smoothed out.
                                      When I first popped the rod cap off it looked like there was no bearing at all and that thin pieces were what I managed to scrape off with a screwdriver.
                                        lol'd at that. when you buy a motor ive found its best to just use the parts and re-assemble everything yourself
                                          this... lol
