  4. compression test gone wrong
21 Posts 15 Posters 1.7k Views
    so I was doing a compression test on my civic and I left the compression tester threaded in the spark plug hole for a couple days and now I can seem to get it out... anyone have any ideas?
      have you tried a really long bolt with that thread pitch maybe put some lock tight on the threads and thread it in. then let it sit. idk
        the hose is stuck on too... the tester I had is only 2 pieces afaik, The dial indicator comes off and the hose and threaded fitting are all in one piece.
          spray pb blaster in that shit and twist like crazy. why did you leave it in after the comp test?
            no idea. got lazy and lost interest.
              well then get to it, and yank that bitch out
                1. Remove head
                2. Vise grips on tester
                3. Remove tester
                4. Reinstall head
                • gsrEKG Offline
                  gsrEKG Offline
                  gsrEK
                  SPANISH-RICE;283875 wrote:
                  1. Remove head
                  3. Remove tester
                  4. Reinstall head
                  that will work, good idea!!
                  2009 Yamaha Zuma 125, gas HOG
                  2008 Honda Fit daily
                  A s2k
                  1991 Honda civic DX Mint SOLD
                  1988 Mitsubishi Mighty max
                  > BlackEJ8;233529 wrote:
                  • darkelvisD Offline
                    darkelvisD Offline
                    darkelvis
                    righty tighty....lefty loosy..
                      Try soaking it with Kroil or a similar penetrating oil.
                        KY...
                          SPANISH-RICE;283922 wrote:
                          KY...
                          Bring him some from your personal stash.
                            win.
                            • Mirage22M Offline
                              Mirage22M Offline
                              Mirage22
                              Start that bitch up on 3 cylinders and rev till it blows up or it pushes the tester out lol!
                              Playtime Performance
                              1993 Mazda RX7 (Montego Blue)
                              1994 Honda Civic CX Hatchback (TEAL)
                              12.5 @ 107 mph
                              14.25 sec. @ 96.19 m.p.h. (B16a I/H/E)
                              2000 Honda Civic DX Hatch Mini-me R.I.P. :(
                                weshole;283928 wrote:
                                bring him some from your personal stash.
                                i only use 5w-30 mobil1
                                • black2gB Offline
                                  black2gB Offline
                                  black2g
                                  so did it pass the compression test?????
                                  1995 Eagle Talon
                                  2000 Doge Neon
                                  1974 Porsche 914
                                  • PhatsP Offline
                                    PhatsP Offline
                                    Phats
                                    hell yes, that has GOT to work
                                    02 GSXR-1000
                                    97 540i
                                      lmao. quality
                                        if it's the civic just leave it and smash it into stuff then crush it... or just say fuck it and pay like all of $20 the head is worth and get a different one...
                                        • blackcherryTSiB Offline
                                          blackcherryTSi
                                          keep twisting as much as you can and see if it frees up, if not pull really hard and try pop the hose part off (cant make it any worse), then there should be a "nipple" exposed that was holding the hose on, take a 1/4 rachet (sp) 1/4 long extension, and a 7/32 socket.... pound the socket on the "nipple" and try loosening it.... this is what i did to mine when it got stuck haha although mine was in three parts so idk if that helped me or not
                                          1995 Honda Civic
