New Stuff
Boost time
New turbonetics TC78
1.15 divided, new f1 turbine, 78mm comp inducer/ 108mm exducer
will support more than i could ever use, yet in a small and light package
I wont be able to tear into this until after harvest, but then it is happening
and an engine bay anticipating new company....
Why did you choose a divided housing??
my guess is so he can run both banks into seperate sections of the turbine.
very nice
DrifterExtreme;285465 wrote:
my guess is so he can run both banks into seperate sections of the turbine.this^
prolly no big deal because this thing should spool very fast regardless, but might as well if i can
most guys get full boost by 3000rpm on this type of combo..... so it will be a retarded powerband
not anymore, the new TC series is the best performing, best spooling turbo for the price on the market by leaps and bounds. This is basically a mini Y2K, uses the F1 turbine wheel which is and has been the best wheel on the market for a long time. Then it uses the standard (cheap) 76 or 78mm wheel in a t04 sized housing. Like zac said, full boost by 3-3400 and capable of 850whp, cant go wrong especially with the ease of packaging
Grr;285513 wrote:
not anymore, the new TC series is the best performing, best spooling turbo for the price on the market by leaps and bounds. This is basically a mini Y2K, uses the F1 turbine wheel which is and has been the best wheel on the market for a long time. Then it uses the standard (cheap) 76 or 78mm wheel in a t04 sized housing. Like zac said, full boost by 3-3400 and capable of 850whp, cant go wrong especially with the ease of packaging76mm inducer and only 850?
Grr;285513 wrote:
not anymore, the new TC series is the best performing, best spooling turbo for the price on the market by leaps and bounds. This is basically a mini Y2K, uses the F1 turbine wheel which is and has been the best wheel on the market for a long time. Then it uses the standard (cheap) 76 or 78mm wheel in a t04 sized housing. Like zac said, full boost by 3-3400 and capable of 850whp, cant go wrong especially with the ease of packagingGood to know. I'm anxious to see how it does!
PSiedTSi;285508 wrote:
Why did you decide on Turbonetics? I've always heard/seen those as overpriced, underperforming turbos.yeah I dunno, I am not really familiar with turbonetics either.... I just did alot of research before buying and the TC's are the rave over in the LSX world.
I guess we will see
but to get a turbo like this with whatever turbine you want, whatever turbine housing you want, anodized compressor backing plate, and polished compressor housing all for $995 seems like a bargin to me
damn zac, this car is going to be fuckin sick!
Parker;285566 wrote:
turbo looks sorta baby dick....big enough you that better get the N20 hooked up
beachbum_jon;285574 wrote:
damn zac, this car is going to be fuckin sick!just need to have the sound again, i miss it.... goes plenty good just NA, just need the sound
you better be working on yours!
fdfreak;285580 wrote:
do you have a manifold(s) made for it yet? VERY NICE!using the c6 corvette manifolds forward and down like they already are in the pics. All i need is to do is fab is a SS hotside from the manifolds to the turbo, and DP.... so not much
im more or less working on mine. if ordering parts and stuff counts as working on it. i cant really do much when i dont have an actual shell to work on, but that should change once i go home for harvest, there is one im going to look at and if its not a rust bucket i'll more that likely buy it and start ording more stuff from granny's
i cant wait to see what this car runs at the track, BA!
beachbum_jon;285625 wrote:
just need to have the sound again, i miss it.... goes plenty good just NA, just need the soundyou better be working on yours!
haha, ordering a bunch of stuff and having a nice big pile of parts is half the fun
hold out and get a good shell, it will be worth it
excited about mine, heck i am excited to see what you will do.... I really want to see someone do a bigger all motor lsx setup on one of these cars...
just knowing how this 6.0 acts, being only NA with only mild NA parts makes me curious to see what a a stroked HC ls2/ls3 variant with a really big cam/heads/intake would do in NA form on these cars...500-550rwhp would easy enough too achieve
it would be sick... get to it
